Anyone have the correct alignment specs?
Having trouble finding an shop that has the alignment specs for the pickup on their machines. Caught the techs trying to use numbers for 4runners or Tacomas.
Did a search including the online FSM but keep getting different results
Here's what I've found so far from different sources:
Source 1
Camber (Degrees) .666 +/- .5
Caster (Degrees) 1.50 +/- .5
Toe (Degrees) .250 +/- .083
Toe (Inches) .125 +/- .042
Source 2
Camber (Degrees) .56 +/- .75
Caster (Degrees) 1.75 +/- .75
Toe (Degrees) .250 +/- .19
Toe (Inches) .13 +/- .09
Source 3
Camber (Degrees) -.1 to +1.2 (0.0 to +.2 Recommended)
Caster (Degrees) 1.2 to 2.2
Toe (Degrees) 0
Toe (Inches) 0 to .0625
This is a DD running 33x12.5 BFGs
Does anyone have the correct alignment specs for a 1990 Pickup SR5 Ext cab V6 5spd 4x4 or have something they can recommend?
Source 1
Source 2
Source 3
Toe (Degrees) 0
kawazx636
07-03-2023 03:03 AM
Longbed 90
03-11-2019 12:38 PM
joeynational
09-05-2015 01:54 PM
