Another odd idle problem
Old 12-07-2009, 06:50 PM
xxxtreme22r's Avatar
This I find very odd. Here's the rundown. Newly rebuilt motor, new alternator, new battery cables. Battery terminals cleaned. Idle at 850-900. When I put the heater on the idle will change about 100 rpm. Is this normal? I think the headlights dim as well when I do this. Also, I don't think its a water pump issue since I have a problem with the heater control valve and that's open full time until I fix the cable that runs to it.
I am thinking maybe the blower motor is worn out drawing more power than it should be causing more of a strain on the alternator resulting in a lower Engine RPM?
This I believe did this before the rebuild as well.
Old 12-09-2009, 08:35 PM
motobro's Avatar
try testing the blower motor with a ohm meter to see how much juice it draws. I think the specs are in the factory service manual
Old 12-09-2009, 08:36 PM
Jay351's Avatar
Mine does the same thing.
From what I have read the big 3 upgrade will fix this...
Old 12-09-2009, 09:12 PM
gonna have to help me out here and explain a bit, still kinda a newbie at these toyotas.
somehow I wound up with a parallel thread and the blower resistor came to mind as well. ( I guess I am a reposter too haha )
Old 12-09-2009, 09:34 PM
Staff
DeathCougar's Avatar
It is a twofold problem.
One, the alternator is so weak that it cannot support many accessories. Two, the cables are fairly small to start. This is why everyone suggests the big 3 upgrade. A friend I helped with his 92 4Runner did the Big 3, and installed an upgraded alternator, and never had this problem again. Even after running a TON of electrical accessories.
Old 12-09-2009, 10:05 PM
2 gauge battery cables and a brand new alternator. I think its the blower motor drawing too much. I will get a chance to look at this tommorow and post up, if I don't freeze to death before then lol
Old 12-09-2009, 10:10 PM
Matt90V6SR5's Avatar
Try upgrading your alternator to a bigger amp.
Old 12-10-2009, 04:42 AM
don't really have the funds for that just yet, and the way I look at it, it didn't do this when it was new, why should it do it now. The only extra accessory I have on the truck is the crappy aux lights.
Old 12-11-2009, 05:12 PM
bone collector's Avatar
Live with it for now. Keep your eye on it. Upgrade your alt when funds premit or mybe a blower motor from a boneyard...
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
kyletbert
07-17-2015 11:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Another odd idle problem
