another 22re biuld
Old 03-25-2008, 07:20 PM
unclejstoy's Avatar
Smile another 22re biuld
Just tho i would share my rebuild.
I got a used moter from some friends in Pa for this build so i could still use my truck.
80% of the rebuild was done at night in 20-30 weather do 2 working long days
Heres a list of the parts i used.
Master kit from EB .20 over pistons, metal t-chain wear pad
EB cam 268c/torker
new timing cover
LC header, cat, cat-back
LC ajusters
MARLIN clutch 1200, master clutch cly
from japan engines new crank,rockers,waterpump
ARP head bolts
I took out the AC and related parts do 2 i never use them and have plans for onboard Air
heres some pics of the moter befor
Old 03-25-2008, 07:25 PM
unclejstoy's Avatar
The head was cleaned valve job / block was was cleaned/bored/honed
also had the intakes cleaned/shot beaded
new/old ajusters
Old 03-25-2008, 07:34 PM
unclejstoy's Avatar
Took about 3months from start 2 finish was not in a hurry. Had 2 order some parts in the middle + it rained/was cold alot not having a garage sucks.
tasty
Old 03-26-2008, 05:45 AM
dirtoyboy's Avatar
does it taste like squirrel?
Old 04-25-2008, 12:05 AM
aktoy's Avatar
Question nice build
Nice build,
thanks for all the good pics. i plan on doing a similar rebuild on my 22re. how do you like the 268 cam? How does the header work with it and i does it idle smooth and have a broad powerband. Where do you feel the most power? thanks for the help
Old 04-25-2008, 12:08 AM
Elton's Avatar
looks nice plz ditch that fram filter asap
Old 04-25-2008, 12:23 AM
YeloSub7's Avatar
nice build! do you have rough estimate of the total $$$ of all the parts?
Old 04-25-2008, 09:17 AM
rbmoomba's Avatar
Nice job. 1I recently did a similar build and I know how nice it is to finally be complete. I had adjustment problems related to the 261 EB cam. Mine is idled up a bit but runs great, the main problem which you don't have to worry about is when the AC is on it idles way down and tries to die when sitting still. No prob when on the highway or cruising at a decent RPM. With the cam, vacuum drops from (stock) 22 inches to roughly 15, and that is the cause of my problems. Researching backup vacuum canisters.
Old 04-25-2008, 11:55 AM
dcg9381's Avatar
So turn the adjuster that's on the upper plenum to adjust your AC-on idle..
Problem fixed.
Old 05-03-2008, 05:51 AM
rbmoomba's Avatar
yeah....then we are way idled up. not a big fan
Old 05-04-2008, 05:27 AM
dirtoyboy's Avatar
needs more cowbell
Old 05-04-2008, 05:42 AM
unclejstoy's Avatar
Cam works fine idles good,
As for the fram that was for the break in oil K&N filters arnt cheap.
Got about 800 miles on her so far. I had a problem with the LC oil pump over pressurizing 80-100 psi and put the one from the rebuild kit on 40-60psi
I have a cold knock I don't know what it is but last 1min then gone I think it;s the T-chain on the metal guide but dunno.
Moter runs great i got 5th gear back pulling the trailer (empty)
i just fingered out gas miles well 1 tank 21 miles a gal but some of that was pulling the trailer/ loaded bed + alinment/ tires are bad. So im expecting it to go up.
Old 05-04-2008, 06:09 AM
unclejstoy's Avatar
I I was gonna keep track of ever receipt and just forgot. i'll guesstimate
ok found some receipt price/ tax/shipping
machine work $275
rebiuld kit $239
timeing cover $49
camshaft & head bolts 155$
rocker arms, water pump, crank $251
$969
i can't find my LC receipts
oil pump $150 ?
header $358 ?
cat $120 ?
cat back $389 ?
valve ajusters $40 ?
$1057
So $2000 crap i spent that much my ass hurts now.
My advice is LC header good........ but get the rest made up at your local shop.
I had 2 hack and weld the crap out of the exhaust system 2 get it 2 fit right Bolt Up my ass.
Old 05-04-2008, 09:21 PM
Blackulua's Avatar
EB cam 268c/torker
new timing cover
LC ajusters
ARP head bolts
I had the exact same set-up except for the cam I had the Engnbldr 270 & clutchmaster clutch.I had 18 to 22 mpg.I totaled the block and rods due to a hydrolock accident.I finished my rebuilt with stock bore block,stock used head,Comp Cam 260S.Just checked my mpg its 21.5 mpg.The motor so far has only 400 miles.Ill never cross a knee high stream again.
I like your set-up and Itll be fun to drive.
Old 05-04-2008, 09:26 PM
iamsuperbleeder's Avatar
that's awesome man; great color scheme too; it's not obnoxious, but looks evil and kick ass, lol
good job though man; I need to get stated on me a rebuild... 285k miles, not sure how much longer this 22re is gonna last with what I put it though, lol
JNapolitano
11-14-2019 07:46 PM
Stull
08-28-2015 05:53 AM
ia02
08-20-2015 11:04 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: another 22re biuld
