All Pro rear bumper is going to fit, one way or another
Old 12-20-2006, 02:30 PM
mt_goat's Avatar
All painted and on now:
After sandblasting I used rattle cans to paint. 1st was a primer coat, then a textured coat, then 2 coats plain gloss black.
Old 12-20-2006, 02:49 PM
Marc P's Avatar
Truck is looking really good Dale.....does it run??
Old 12-20-2006, 02:58 PM
mt_goat's Avatar
Like a bat out of hell!
Old 12-22-2006, 01:36 AM
JRyota94's Avatar
What kind of Fender Flares are those?
Old 12-22-2006, 05:24 AM
  #25
mt_goat's Avatar
Bushwacker
Old 01-08-2007, 02:51 PM
  #26
mt_goat's Avatar
I added one more little thing to this bumper, a receiver mounted tow ring and step.
The tow ring mount is cut out of some 3/4" thick plate and goes all the way through the receiver with a hole drilled for the pin:
The step was cut from 1/4" thick plate and just welded on the top.
Old 02-09-2007, 05:00 PM
  #27
hutch24's Avatar
With the extra tubing do you think you boosted the tow capacity enough to tow a couple thousand pounds. I need a new rear bumper and was thinking about going with this one but I need to be able to tow a two place snowmachine trailer.
Old 02-09-2007, 05:23 PM
  #28
Scofco's Avatar
Way to be, that bumper looks gorgeous.
You have to love when you take a chance and everything works out.
Old 02-09-2007, 07:13 PM
  #29
mt_goat's Avatar
Yes, I'd feel good about towing another truck with it now.
Old 03-16-2011, 08:15 PM
  #30
weikel81's Avatar
i kno this is an old thread but i just wanted to say that the bumper looks amazing on that older pickup and it makes my want to do the same thing to my 94.........i was just wondering if cutting the roll pan was the only mod youu had to do besides drilling the holes??
Old 03-17-2011, 05:17 AM
  #31
mt_goat's Avatar
Pretty much that's it, IIRC I needed a thick washer under each bolt on one side. Also keep in mind that I have a 1" body lift. Not sure if that would make a difference or not, probably not since there looks to be room to move the bumper down on the frame. Good luck
Old 02-09-2014, 07:51 PM
  #32
alfio's Avatar
mt_goat, do you have pics of your install? the ones you had originally posted aren't showing up. thanks
Old 02-10-2014, 03:43 AM
  #33
wyoming9's Avatar
Red face
Wow talk about a old thread.
Old 02-10-2014, 04:32 AM
  #34
alfio's Avatar
start a new thread (say looking for an all-pro bumper on a second gen truck) and people will say... search! if you find one and refloat it, you are necroposting.... damned if you do, damned if you don't
Old 02-10-2014, 02:20 PM
  #35
mt_goat's Avatar
Most of them should be here: http://s796.photobucket.com/user/mt_...=recent&page=1
Old 02-10-2014, 03:43 PM
  #36
alfio's Avatar
thanks!
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
icentropy
07-09-2015 02:12 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: All Pro rear bumper is going to fit, one way or another
