All Pro Parking Brake HUMMMM
Old 02-01-2008, 06:50 AM
Tick's Avatar
I just got my Parking brake from allpro .
I have a 1991 Toyota Pickup 4x4, I got it a year ago and i am not sure if the transfer case has ever been changed and there is no way to get in contact with other owner. So i thought i would ask the PRO's.
My Problem is the bolt pattern on the brake and the bolt pattern on the transfer case will not line up. All Pro add says Fits 84-95 gear drive 4cyl transfer case equipped pickups and 4Runners. Can someone tell me if this is the original transfer case for this truck or has it been changed. Has anyone ever had this problem with the all pro parking brake before?
If there is not enough info let me know.
I forgot to mention i am a newbe
Old 02-01-2008, 07:12 AM
CanTheWhales's Avatar
Dumb question, but were the chain driven cases have a different bolt pattern? I don't remember right now the years they were used and stuff....It's been a long Friday at work (and it's only 11:15AM)
Old 02-01-2008, 07:15 AM
4runner4ever's Avatar
That's not a G or W series X case, but a R series, not gear driven but chain driven. That should be bolted behind a V6.
You will have to fab you'r own bracket for that application. Here's mine:
Old 02-01-2008, 07:17 AM
^ Sweet I was right (sort of), so was it 4=gear & 6=chain or is it more of a year thing? Damn I can't remember...
Old 02-01-2008, 07:34 AM
Tick's Avatar
Nice work
Do you sell them LOL
If you don't you should ....
Thats nice
Old 02-01-2008, 07:35 AM
Yep, that's correct.
Only the 22R-T uses a gear driven R seies I think.
Old 02-01-2008, 07:52 AM
Right, but anyone with a turbo probably blew it up/drove into a tree by now... wish I could find one
Old 02-01-2008, 08:12 AM
I have a swap, turbo, intercooler and I'm still alive......
Have to admit that the brakes are somewhat "yugo" like....
I have started my own business so who knows, mayby I start producing something. Got a lot of requests about my bumper also. Anyone of you handy with a welder?, I can email the plans and you guys can wire back some money
Old 02-01-2008, 08:37 AM
Tick's Avatar
I see 3 bolts to your T case .... is there more then that ?
Old 02-01-2008, 09:29 AM
It's 4 bolts.
Old 02-09-2008, 04:51 AM
Tick's Avatar
Did you have to move your E brake cable at all ??????
By the way i made the mounting bracket thanks for the tips .
Old 02-09-2008, 05:16 AM
I made a new bracket for the cable due to the 3 link front SAS. It should be okay since mine still is located in about the same spot, just a different bracket.
Good luck.
Old 02-09-2008, 09:17 AM
Etype R's Avatar
I would love to get a set of plans and material/parts list to build one of those... My parking brake has never worked, and I would prefer to get a tranfercase parking brake setup over fixing the stock setup.
Old 02-09-2008, 02:35 PM
Tick's Avatar
I may have to mod the bracket for the cable, it is pulling on a 90 degrees now. I am not going to relocate the bracket just going to cut some out and bend it in and weld it back up so it is not pulling on a angle. Thank you again for all the ideas and the pic's it helped me allot.
Later
TC
Old 02-10-2008, 08:32 AM
Tick's Avatar
My brake light is on .... did you have to do something to your brake light switch?
Old 02-10-2008, 08:51 AM
No, no mods. The cable probably got messed up cause you had it loose while working. Check your parkingbrake mechanisme. There's a small peg which actuates a switch. Check inside the slot it runs through to see if the cable isn't catching something. This usealy only happens if you pull the lever with the cable disconnected and than push it back in. Cause there's nothing to keep the innercable tight it useally catches something, get's bend etc.
Old 02-10-2008, 09:04 AM
Tick's Avatar
Just looked at it
Even when i push in on the the switch with my finger the brake light still stays on .... i guess it is the switch ?
What do you think ?
Old 02-10-2008, 09:10 AM
The brake light is also the vacuum indicator. Mine sometimes stays on and stops as soon as I drive a few feet and use the brake.
If you can short circuit the switch and it stays on it's definately something else.
Old 02-10-2008, 01:34 PM
drew303's Avatar
Why did you get a driveline brake to begin w/ ? Just curious.
The only reason these are produced is for rear disc brake swaps where you dont use calipers w/ the parking brake mechanism because thats a b**h to fab in.
Otherwise the stocker setup is much better.
jashoeuh
11-26-2017 07:01 AM
skoob
10-15-2015 03:23 PM
priest16
15
08-06-2015 07:43 AM
terminator
07-27-2015 07:13 PM
CanRunner
07-20-2015 01:29 PM
Quick Reply: All Pro Parking Brake HUMMMM
