advice on 3.4 swap
Old 08-12-2013, 12:05 AM
bwilliams's Avatar
advice on 3.4 swap
i have a 1990 toyota pickup with the 3.0 L and automatic transmission. i want to swap this with a 3.4l and a 5 speed tranny. what would go into doing all of this? from what i have seen the motor will mount up fine but all of the wiring and exhaust is the challenging part. what would you recommend i do? do the swap or rebuild my 3.0 and auto tranny. if anybody has a write up on this or can direct me to a write up that shows me how to do this that would be awesome.
Old 08-12-2013, 08:21 AM
SacRunner's Avatar
https://www.yotatech.com/forums/f160/
Mechanically, yes, the 3.4 will bolt up in place of your 3.0, engine mounts and transmission but that's where it ends.
Just about everything under the hood will have to swap sides, because the intake on the 3.4 is routed to the passenger side vs. the driver's side with the 3.0.
Electrically, everything is different.
Read through the stickies and a 5-10 of the various builds to get an idea of what you're getting yourself into. If there's nothing wrong with the 3.0 (aside from being a 3.0), I would leave well enough alone for now, do as much research as you can, and start looking for a donor.
Old 08-12-2013, 12:54 PM
RSR
RSR's Avatar
You can do the swap for basically the same price as rebuilding your current rig, especially when you factor selling your old engine/tranny if applicable. ToyOnlySwaps.com sells swap components or do it for you. ORS has a good overview and sells parts too: http://www.offroadsolutions.com/tech...fe-conversion/
From a cost standpoint, they're the same. From a complexity standpoint, the swap is harder, but for me -- paying someone like ToyOnlySwaps ~$1500 in labor to do it for me is well worth saving me the pain and frustration of taking a month or two of frustration trying to do it myself... And I actually get something better from the end result of the effort. More power and better mpgs.
Old 08-12-2013, 01:35 PM
wyoming9's Avatar
Red face
you might want to check out our 3.4 swap section.
It should give you a little something to read.
Old 05-11-2016, 02:27 PM
jwade's Avatar
i am doing the 3.4 swap as well... I want to rebuild my tranny tho and just beef it up. what should I get for the transmission upgrade that will work well with the 3.4
Old 05-11-2016, 05:21 PM
wyoming9's Avatar
Red face
Might help to know just what Transmission ??
Are you doing the work Yourself ??
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
94whiterunner
07-12-2015 07:15 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: advice on 3.4 swap
