adjusting clutch?
Just another question to you jason.. I notice a little bit of noise coming from tranny now. Sounds like a bearing spinning. (as if throwout bearing was bad) ie. push clutch in sound goes away. The sound is very faint but didnt have this before. Could this just be brand related also or what
If you push the clutch in and the sound goes away, it is not the throwout bearing or the pilot. Not sure what your noise is though...
Is it a new noise? What you are describing seems to be tranny related.
#25
Yes its a new noise. I had a throwout bearing go out before and that is exactly what it sounds like. When you press the clutch in the sound goes away when in neutral just idling you can hear it. Definitely a new noise but could just be that it still needs to be broke in like i said i just replaced this today and took it for a five mile drive that's it.
#26
Wouldn't the throw out bearing only make noise when the clutch is in. When the clutch (pedal) is out, the throwout bearing is just chillin' there, so it won't make any noise.
(I'm off to bed so I'll catchya later)
#28
my throw out bearing made noise until i touched the pedal a little bit. When i took it off it was wobbily on the input shaft and it would rattle it there was no pressure on it from the clutch fork.
he's gone
7
12-03-2019 07:08 AM
89fourrunner
02-17-2016 06:52 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
1992, 1994, 4runner, adjust, adjusting, adjustment, centerforce, clutch, clutchadjust, cluth, pedal, photo, sr5, toyota, yotatech
