95 4Runner 3vze acceleration problems! HELP!!!!
Old 08-26-2011, 12:03 PM
flipemflopem's Avatar
I have had it! She looks immaculate in every way, but if I can't fix this thing soon the AR15 is gonna start barking fire at her till I fell better!( 2500 rounds should do it...)
I know that the 3vze is a slug and that's why call it the 3.Slo, but this is just way beyond that... it more like a 3.wontgo now...
I just finished rebuilding the entire motor and Im sure everything in there is fine... the compression is 163-166 in all cylinders, and it runs and idles great.... mechanically the engine is all in spec...
The issue I'm having is trying to drive it!! its runs EXTREMELY rich and has no power whatsoever... And is not showing any codes at all!! i can get it up to about 40 - 45 MPH , it just takes a while...
Any ideas? could really use a good think tank session about now!!
also, it has new plugs, wires, cap, rotor, TPS has been tested and adjusted as per FSM. timing is at factoy spec, new fuel filter....
could the knock sensor be shot? or O2 sensor? I just figured id get a code if it were either one if them???
Old 08-26-2011, 12:40 PM
TNRabbit's Avatar
How many miles on the O2 sensor? They are pretty much out of spec by 100,000 miles. But that won't cause your rich fuel problem.
I'd guess an issue with the VAFM first. If not, then maybe it thinks the engine is cold & giving extra fuel. There are two coolant sensors, one in the TB, one at the coolant distribution block behind the intake next to the firewall.
Old 08-26-2011, 01:40 PM
I'm not sure how many miles are on it but it looks fairly new..... I got underneath and unplugged it and still no CEL or anything.... I'm going to ohm it out and see if its good.
Old 09-02-2011, 07:02 AM
well for an update... ECM was bad, rare but still sometimes happens! Runs like a champ now, thanks for all the help and advice everyone!!
Old 09-02-2011, 07:55 AM
BMcEL's Avatar
The computer failing by itself is rare but the windshield leaking on it is not.
Old 09-03-2011, 07:41 AM
That's exactly what happened to it
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 95 4Runner 3vze acceleration problems! HELP!!!!
