94 Runner 4WD Low not engaging?
Old 01-01-2006, 07:12 PM
Zackb911's Avatar
My 1994 4runner 3.0 Auto shifts into 4WD high fine but does not go into 4Low.. Anything I should check?
Old 01-01-2006, 07:18 PM
91Toyota4x4's Avatar
have you tried shiftinh into 4Low in Park and nuetral??
Old 01-03-2006, 02:02 PM
Zackb911's Avatar
I tired in Park nuetral and everyother gear and the shifter wont move down to it? Anything else I can check?
Zack
Old 01-03-2006, 02:39 PM
Tragic Drive's Avatar
Hi Zack,
Did you unhook the linkage from the transfer case to see if you can move the poistioner on the case ?
Old 01-03-2006, 02:59 PM
rosspa75's Avatar
Try pushing the 4x4 shifter to the side then putting it in 4 lo
Old 01-03-2006, 05:33 PM
Zackb911's Avatar
Thanks that did the trick but now Im questioning my intelligence...
Old 01-03-2006, 05:41 PM
rosspa75's Avatar
LOL, Don't feel bad, After using 4 lo several times since I've had my truck...the other day I couldn't get it to go into 4 lo, I tried and tried for like 20 minutes, I finally remembered to push it over and shift.
Gamble_STi
07-01-2015 12:51 PM
rwh2toyota
13
06-27-2015 05:39 PM
TheManOutside
06-18-2015 03:32 PM
williemon
06-21-2002 01:32 PM
Quick Reply: 94 Runner 4WD Low not engaging?
