94 fuel pump change out
Old 04-22-2012, 10:46 AM
94Beater's Avatar
What is the easiest way?
Old 04-22-2012, 11:11 AM
scope103's Avatar
I've never done it, but I'd start with reading the manual.
http://www.ncttora.com/fsm/1990-1995...e/fuelpump.pdf It doesn't look that hard.
Old 04-22-2012, 12:39 PM
TNRabbit's Avatar
Easiest way is to pay someone else to do it.
Which engine/vehicle?
Old 04-22-2012, 05:18 PM
Rob510's Avatar
Is it a truck or 4runner? If it is a truck, removing the bed isn't that bad. Start by spraying your bed mount nuts with PB blaster or something better than WD40 a couple of days ahead of time. Then remove the tailights and loosen the harness from the bed, disconnect the fuel filler neck, and remove all the nuts that hold the bed on from underneath. I used two ratchet straps to make a x across the bed hooks then an engine crain to lift the bed up and moved it back and rested it on the tires. That will give you enough access to get the pump out.
Old 04-22-2012, 05:20 PM
Rob510's Avatar
Oops double post
Old 04-22-2012, 06:29 PM
TNRabbit's Avatar
Pics here for a pickup:
https://www.yotatech.com/forums/f116...repair-239734/
smthwsn357
12-04-2023 02:08 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 94 fuel pump change out
