94 3.0 v6 vze engine timing chain
Old 08-11-2009, 10:16 PM
matthewtdean's Avatar
Thumbs down 94 3.0 v6 vze engine timing chain
Existing timing chain did not have any marks, I looked at it under excellent lighting with a magnifying glass. New belt has one set of arrows (all placed together and point the same direction) and one yellow line, but no other marks.....
So how do I get the timing lined up. I get the parts about putting the camshaft and the crankshafts into position, but does anyone know the tooth count from the crank to the first pully?
Old 08-12-2009, 03:42 AM
buckz6319's Avatar
here this thread may help you assuming you have a timing belt?...https://www.yotatech.com/forums/f116...s-pics-183911/
Old 08-12-2009, 03:50 AM
TNRabbit's Avatar
There are at least a dozen threads on this. You don't need marks on the belt; you just need to line up the crank mark & the cam sprocket marks. Check these threads, which you can find easily with the SEARCH button:
https://www.yotatech.com/forums/f116...advice-117486/
https://www.yotatech.com/forums/f116...advice-179570/
https://www.yotatech.com/forums/f116...ey-2-a-177592/
https://www.yotatech.com/forums/f116...g-20-a-178761/
https://www.yotatech.com/forums/f116...er-3vz-181019/
https://www.yotatech.com/forums/f116...estion-118098/
Old 08-12-2009, 07:55 AM
OutlawMike's Avatar
The marks are more of a distraction than anything else. Don't need them. Just make sure the timing marks on the cams line up after rotating it as per the FSM.
Usually you find you are a tooth off the first time, and nail it the third time.
It will take two people to do it right, you need the four hands.
Good luck
Old 08-12-2009, 08:49 AM
TNRabbit's Avatar
I have done it twice now with my two hands, but it sure would have be a lot EASIER with four~
Old 09-06-2009, 10:12 AM
Thumbs up Timing chain
Thanks to all who replied. Lining up the marks worked on the crankshaft pully as per the FSM along with lining up the camshaft marks worked just fine.
Old 01-09-2010, 07:03 PM
clocklaw's Avatar
My belt doesn't have any marks. Does anyone have a count of the number of teeth between the marks so I can mark my belt before installation???
Old 01-10-2010, 05:23 PM
bugs1961's Avatar
No marks are necessary. See post #4 above.
Old 01-10-2010, 06:51 PM
clocklaw's Avatar
Ok, we got it without the marks...fortunately I am working with a professional!
some drunk guy
08-03-2021 06:09 PM
mtrdrms
09-26-2015 07:12 AM
EatChipsNow
09-09-2015 01:25 AM
FJtoyman
09-08-2015 04:47 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: 94 3.0 v6 vze engine timing chain
