94 3.0 overheating?
Old 09-02-2010, 05:11 PM
jbridered's Avatar
94 3.0 overheating?
My 94 v6 4x4 is overheating while pulling a 13ft scamp (light trailer). I removed the Thermostat so that isnt the problem. After the t-stat removed shouldnt i see good flow when the radiator cap is removed? I dont see good flow which leaves me to believe there is a blockage somewhere. My radiator was rodded out about a year ago. Any suggestions?
Old 09-02-2010, 05:56 PM
iselloil's Avatar
Fan clutch.
Old 09-02-2010, 07:27 PM
jbridered's Avatar
So even though the fan is turning fine? Shouldnt i see flow in the radiator since i removed the thermostat?
Old 09-02-2010, 09:26 PM
pruney81's Avatar
It could be the water pump...since you're not seeing any flow in the radiator
Old 09-03-2010, 05:38 AM
iselloil's Avatar
Got to see flow.
Old 09-04-2010, 11:24 AM
jbridered's Avatar
Waterpump is not leaking. I am gonna do a real good flush and see if it makes a difference.
Old 09-04-2010, 11:30 AM
camo31_10.50's Avatar
flush it first.
it could be the water pump...just cuz the water pump isn't leaking...doesn't mean it's pumping
Old 09-08-2010, 07:09 PM
jbridered's Avatar
I flushed and noticed flow in the rad. I took it to town and drove it for about an hour after the flush and it started to get close to the red when i was about 5 minutes from home. I lifted the hood and found the rad hose from the motor had two holes in it. I never noticed this before so i think its just old and couldnt stand another really hot one. I am thinking my rad is the problem. Any advice on whether to tell if its the waterpump or rad?
Old 09-08-2010, 07:26 PM
91_TOYOTA_4x4's Avatar
my 3vze gets hot if it sits for more than 5 mins, other than that its right where it should be. im thinking my water pump is done. sounds like you could have a block in the system, but i would do a water pump. there isnt much of a way to tell if its bad so just take it off and replace it. i think they are like 130 bucks and you get a new timing belt too
Old 09-10-2010, 04:27 AM
TNRabbit's Avatar
It's the radiator. You can get a new all metal radiator from CSF online for about $200.00.
Check my thread: https://www.yotatech.com/forums/f116...d-pics-193478/
Old 09-10-2010, 08:02 AM
jbridered's Avatar
rad rod
Can you rod the radiator more than once? Last time they did a good job.
Old 09-10-2010, 02:22 PM
starrjewel's Avatar
I am actually in the process of changing out the water pump in my 93 Toyota T100 4WD 3.0 I started with the radiator because of the obvious 5" fine crack in the very top. After replacing the radiator, I filled with coolant and hoped there weren't other components causing the overheating.
Unfortunately, it overheated again with the new radiator. I drained coolant and replaced thermostat. I let it run at normal temp for about 10 min with no signs of increase in temp.
I drove it to work that night and everything seemed fine. I came out 3 hours later to do a bank run and noticed my precious coolant all over the ground and the water pump dripping underneath.
I am now opening up the timing cover and trying to replace the water pump. I haven't done this task before so its definitely a learning experience! Since I have to take timing belt off and be so careful with the positions, I'm replacing it as well as the timing tensioner and idler. I bought new spark plugs to swap out. I am hoping that this job will make my yota run ever so beautiful! It has 150K on it and needed a little internal TLC!
Many have told me I don't have to change belt, tensioner or idler but its never been done. Sure as I try to put it all back together that's when it would fail on me and destroy my timing and everything else that is kept in line by it.
LotOMiles
09-14-2015 11:45 PM
sanctfy
09-13-2015 06:33 PM
noahstancik
09-10-2015 10:47 AM
FJtoyman
09-08-2015 04:47 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: 94 3.0 overheating?
