93 v6 5 speed issues... rebuild?
Its slips out of first, wont downshift into 3rd. what would you do? Whats the tranny model number?
thanks
thanks
mine was popping out of first and would always grind going into reverse. I threw a marlin crawler shifter seat and the ball that goes on the end of the shifter on it and now its tight and shifts better than any of the 10-15 yota's I've driven.
Try the er seat and bushing (a must do for any r150 trans) from marlin crawler. Then check for cracks in the clutch pedal bracket like Tn mentioned.
If its still problimatic, then look for a used trans. You can get them for under $250 with a transfercase. 89-95 is all the same with the exception of the electric/cable speedo.
thanks everybody. Ill get the bushing first. It is sloppy.
Which color bushing for my tranny?
By the way if I do get a tranny what years of the r150f have the same speedo connections?
shadowbirdie
07-21-2015 10:38 PM
