93 T100 engine swap options
Old 08-01-2006, 07:18 PM
Sandman's Avatar
My dad has a 93 T100 6cyl auto and wants to swap in a stronger/newer engine. The truck is in great shape, but the engine is on it's way out. What are some ideal donor vehicles/engines to hunt for? Direct bolt-in would be great. Advice or direction would be appreciated.
Old 08-01-2006, 07:26 PM
Cebby's Avatar
Only direct bolt in is the same 3.0L. Later models came with the 3.4L V6.
More involved, but certainly more power would be the Lexus 1UZFE (4.0L V8) or a small block Chevy motor.
What trans?
Old 08-02-2006, 02:48 AM
Vrooooom's Avatar
I have a 3.4L from a 97 T100 for sale if you want to do a conversion: ($650)
https://www.yotatech.com/forums/f180/97-t100-5vz-3-4-sale-91002/
Old 08-02-2006, 05:31 AM
Sandman's Avatar
(Cali is a little far for me Vrooom-thanks anyway)
The later T100's v6 sounds like an option.
How about Tacoma's? I'd take the tranny too..even transfer case.
Old 08-02-2006, 05:58 AM
mt_goat's Avatar
Yeah that's a great option. Mike at ORS can help with that: http://www.offroadsolutions.com/products.htm
Old 02-08-2007, 06:34 PM
Sandman's Avatar
ok..the current engine just blew.
For now we're just going to try to find another 3.0 and throw it in.
Will any of the 4runner 3.0s bolt right up or are the mounts different?
Old 02-08-2007, 08:52 PM
breknraj's Avatar
If the engine is gone, I would really recommend trying to find a good 3.4 set up to put in it. It should be even more straight forward than dropping it into a truck, like a lot of us have. You would definitely appreciate the extra power for your bigger T-100.
If you think you can do a 3.0 swap on your own, then you can do the 3.4, too. Look into it - I'm sure that you'd like it!
Old 02-08-2007, 09:13 PM
CJM
CJM's Avatar
Dump the 3.0 in favor of anything else really. I have the 3.4 in my T and its great!
Old 02-09-2007, 02:39 AM
Sandman's Avatar
well the transmission is an automatic - I understand that = more $$$ for a 3.4 swap. Is it still worth it? I'd love to throw in a 3.4, but I don't want to get carried away. Need advice here.
Old 02-09-2007, 04:20 AM
mt_goat's Avatar
I like what Adrian says, only do the 3.4 swap if you can do it yourself and you love your truck and plan to keep it forever.
Old 09-14-2010, 01:03 AM
molokaiboy's Avatar
im planning to do the same swap,i got my engine already but the fear has come to the wiring part, ors is gone no one is answer the phone or emails, my truck is the same as your, 1993 t100 auto trans with a passenger drop side t-case. people told me the engine with bolt in and that the t100 computor will run it. because im still reserching about it. correct me if it not correct
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 93 T100 engine swap options
