93 pickup not shifting through 3-4th correctly
Old 11-07-2014, 11:50 AM
aznorthyota's Avatar
just bought a higher mileage 93 pickup 4x4 3.0 v6. transmission a340-h.
It is missing shift points for 3rd and 4th gear when trying to reach highway speeds. no clunking or grinding just riding at 4500 rpms when it should have shifted around 40mph and up. I checked tranny fluid and tested for codes using the paper clip method. It is not throwing any codes. I have read that the shift solenoids have these symptoms but usually throw code 62. No idea where to start any help??
Old 11-07-2014, 12:03 PM
scope103's Avatar
The answers to all questions are found in The Good Book:
http://personal.utulsa.edu/~nathan-b...autotrans.html
There are several codes (for different solenoids and the like), but you have checked and found none (do read the manual and verify you are doing it correctly; you need to watch the O/D light, not the CEL).
Lockup and O/D are both deferred when the engine is cold. You may need to check the ECT (engine coolant temperature) sensor. The actual shift points are determined (in part) by the TPS (Throttle Position Sensor). You, my friend, are in luck: with the A340H you can verify the operation of the TPS directly through the transmission using the Tt pin of the diagnostic connector (see Electronic Control System in the manual).
smthwsn357
12-04-2023 02:08 AM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 93 pickup not shifting through 3-4th correctly
