93 3.0 v6 needs a tune-up. Can anyone help?
Old 03-25-2006, 07:29 AM
ByThaBay's Avatar
Hi there,
I'm located in San Francisco and my '93 v6 pickup needs to have the timing belt, water pump, and pulleys replaced. I would like to do the job myself but I'm scared to screw anything up...
Any volunteers? I'll provide the pizza & beer
-Eugene
Old 03-25-2006, 08:04 AM
tc
tc's Avatar
I was a little nervous about doing mine too. If you're reasonably mechanically inclined, you can do it. There are several writeups on here how to do it.
Old 03-25-2006, 10:18 PM
ByThaBay's Avatar
I still insist on having someone watch over my back and give me hints. I cannot afford to make a mistake.
Old 03-26-2006, 07:12 AM
leebee's Avatar
try this:
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
i did mine over the christmas holidays, go slow and read things as often as you need to make sure you have it right. its a time consuming job but doable by yourself. im pretty sure there are a few members nearby that may be willing to help out.
good luck and keep us posted.
lee
Old 03-27-2006, 07:38 AM
ByThaBay's Avatar
Originally Posted by leebee
try this:
lee
it says you need several different SST tools and a shop press...?
Old 03-27-2006, 11:04 AM
tc
tc's Avatar
I can't imagine what you would need the press for...
The SST's make things more convenient, but aren't necessary. (I didn't use any!)
Old 08-08-2006, 03:22 PM
ByThaBay's Avatar
It says in the instructions that you have to remove the power steering pump pully and the pump itself from the engine.. do I actually have to remove the power steering pump?
Old 08-08-2006, 05:48 PM
TNRabbit's Avatar
The PS pump is the biggest PITA in everything you're about to do. I highly recommend you remove the PS Pump and the radiator, too. I didn't and it made things a lot more difficult.
Old 08-09-2006, 12:32 PM
ByThaBay's Avatar
I don't mind removing the PS pump... however, I would like to know how exactly it should be removed. It looks like the pulley needs to be removed first, how do I remove the pulley? There is a screw on it I think, do I unscrew it counter-clockwise? How can I unscrew it without having the pulley move?
Also, the step where they say disconnect PS pump from engine, do I actually have to remove all of the connections to the pump, or should I just keep it connected but move it aside from its mounting location?
Old 08-10-2006, 04:53 PM
TNRabbit's Avatar
I was never able to remove my pulley; I ended up bending the crap out of it with a 6-foot steel bar and it STILL didn't come loose. Good thing I was replacing it anyway!
4wayout
07-01-2015 05:17 PM
John163
05-18-2009 08:28 PM
matthewdmueller
05-19-2008 12:11 PM
matthewdmueller
05-19-2008 12:09 PM
Quick Reply: 93 3.0 v6 needs a tune-up. Can anyone help?
