92 toyota 4runner sr5 wont shift out of first until redline
Old 05-07-2010, 04:52 PM
desert-rat660's Avatar
Hey guys i just bought a 92 4runner sr5 4x4 i bought it for $1000.00 not running, i put a fuel pump in it and got it going, but when i drive it, it wont shift into second gear until 5500 rpm, i changed the fluid and did an ohm reading on the solenoids, and applied voltage to them they all activate. Im not sure what else to check, do u think i need a new trans? any help or pointers will be appreciated
Old 05-07-2010, 06:17 PM
rustypigeon's Avatar
Check the TPS. If your TPS is telling your ECU that the throttle valve is open more than it is, your ecu will delay the shift point to a higher rpm.
Eta: Actuallu a bad tps would cause all the shift points to change, not just first.
Old 05-08-2010, 06:57 AM
R.DesJardin's Avatar
Shifting
Check all the wiring for the TPS, VSS, TCM and everything in between. Really sounds like an electrical issue.
Old 05-08-2010, 08:38 AM
yeah i have checked everything, electrical, i have no codes either, im going to manually apply 12 volts to teh #2 shift solenoid and see if it does shift when i do that
Old 05-08-2010, 08:56 AM
Energizing the number 2 shift solenoid will give you third gear. Both solenoids need to be energized for second gear.
Can you get it to shift from 1-2 by manually shifting from L to 2?
Old 05-08-2010, 09:18 AM
no but i know that number 1 solenoid is energing, so if i energize number 2 it should give me 2nd gear, if i manually shift it into second gear it engages about 4500 rpm instead of 55000 rpm in drive
Old 05-08-2010, 02:07 PM
Matt4Running's Avatar
Your truck can rev to 55,000? RPMS?..thats impressive,lol.Wheres the pics of the 4Runner?
Old 05-08-2010, 02:12 PM
sorry i ment 5500 rpm, anyways i was testing the tps, i back probed the vta wire and checked the voltage, its 3.8 volts no matter what throttle angle im at, shouldnt it vary from up to 5 volts? i know u are supposed to ohm it but the damn thing faces rearward toward the manifold and i dont feel like pulling it off
Old 05-08-2010, 02:23 PM
Kiroshu's Avatar
Does the truck have the right alternator? Theres a specific alternator for a manual and an auto. If you have a manual alt in an auto truck it may have this problem. Checked fluid? While running? Is it full? Pour some lucus oil stop slip in there. It may help. I've used in on alot fo trucks where valves in valve body were hanging up. Check kick down cable.
Old 05-08-2010, 02:27 PM
yeah ive done all thatchanged the fluid and i did add lucas, im just wondering about my tps voltage
Old 05-09-2010, 01:15 PM
fixed, the tps was stuck at WOT. shifts smoothe now
Old 05-31-2010, 07:30 AM
well my victory was short lived, the planetary exploded in the trans, i hate automatics. i just finished swapping in a 5 speed from a 90 4runner, im much happier
arlindsay1992
01-23-2024 01:34 PM
vasinvictor
01-20-2016 12:39 PM
95Runner
06-09-2002 09:08 AM
Quick Reply: 92 toyota 4runner sr5 wont shift out of first until redline
