92 with 3.0 6cyl EFI WHat engine?
I have a 92 4x4 PU with 6cyl EFI. I am trying to download manual from
http://forums.bauchan.org/portal/downloads.php?dcid=17
and need to know how do I determine what engine I have to download correct manual. Any help much appreciated.
Is this the link you are referring to???
If so I am not sure what one to download. Thanks
he means at the top of the main page of this forum....
here:
https://www.yotatech.com/forums/f116...l-link-131168/
or better yet:
http://www.ncttora.com/fsm/1993/index.html
or EVEN BETTER:
a search of this forum would yield these same results. also recommend reading the crap out of these forums. you'll learn a lot.
here:
or better yet:
or EVEN BETTER:
Spoonist and others, THANKS ALOT. I followed the first link spoonist gave me but could NOT figure out what one to DL, second link is great also. Having MAJOR fulke problems, truck runs one min the cant get it to run again. My first thought was fuel filter but more I read less I think thats it. Kinda a bitch since we have no other vehicle at this time and this truck has turned out to be a PITA, seem to work on it more than we drive it, UHG! Thanks ALL, very much!
friend, the "6cyl efi" is the 3vze which is the engine that you have. If you think you don't, or arent sure, look under the hood. If there are 6 spark plugs, its a 3vze. If there are 4, its a 22re. If there are two exhaust manifolds, its a 3vze. If there is one (on the drivers side) then its a 22re.
heh...It should also say "3.0L" somewhere on the engine I'm pretty sure. Either that or "3vze"
there is a block stamping but its virtually impossible to make out when mounted in the truck because of were the exhaust manifolds are and engine mounts... but if you were looking at a raw block (at say a pick and pull and wanted to know) they would be there.
Must just say "TOYOTA", huh?
ZONAYODA
07-13-2015 07:17 PM
