'91 Truck clutch problem
Old 04-18-2013, 02:22 PM
acarignan's Avatar
I've got a '91 Truck. It's a 2wd with the 22RE and 5 speed trans only at 88k miles. When I depress the clutch pedal it stops halfway to the floor like there is an invisible barrier there. I can move the shifter between gears but it acts as if nothings happening like shifting when the truck is off; no grinding, engagement etc... I know it's not the pilot or throwout bearing and the clutch itself was still good when it worked. That leads me to believe it could be the master or slave cylinders or could it be the fork. Has anyone had any problem or dealt with a situation like this before? any info would be greatly appreciated.
Old 04-18-2013, 04:50 PM
slacker's Avatar
search - clutch pedal bracket .. and have a read .. might just be your problem
Old 04-18-2013, 05:07 PM
acarignan's Avatar
Thank you. I'll read up about it.
Old 04-19-2013, 08:34 AM
acarignan's Avatar
It's not the bracket, from what i can tell it has already been replaced. Could it be a master cylinder failure?
Old 04-19-2013, 10:16 AM
weaselman's Avatar
How do you know it's not the throw out bearing? One of the clips might have broken and its getting jammed. It shouldn't stop half way something mechanical is getting jammed.
Old 04-19-2013, 10:33 AM
acarignan's Avatar
It never gave any usual signs of the throwout going bad. It just died. Could it be however the fingers on the pressure plate are shot?
Old 04-19-2013, 11:31 AM
Gamefreakgc's Avatar
I'd operate it by hand and take a peek under the dash. Might want to remove the lower dash cover to see it better. Definitely sounds like something is either getting in the way of the pedal or the spring.
Either that or you might have some severe blockage of fluid somewhere. I've never heard of that happening though.
Old 04-19-2013, 11:41 AM
acarignan's Avatar
I laid under there and pushed it by hand and it moves just fine and then it's like the master cylinder shaft just hits a wall and stops motion. Honestly with how weird this situation has been a blockage wouldn't surprise me. It started out of nowhere after I removed the bed to do the fuel pump and stuff.
Old 04-19-2013, 01:32 PM
weaselman's Avatar
It could be. Anything is possible. Does it start and run without any noises? One of the springs could have exploded from the clutch disc and stopping the pressure plate from operating normally. Not to sure honestly. I've never hear of a fluid/line blockage thy severe.
Old 04-19-2013, 04:52 PM
acarignan's Avatar
It fires up just fine, the engine runs perfectly but I can't get it to disengage the clutch or anything.
the1998sr5
10-19-2016 12:48 PM
voiddweller
19
05-02-2016 09:10 PM
Dillon1983
07-07-2015 06:47 PM
dirtrider0129
10
06-24-2015 12:24 PM
YoterTillDeath
07-04-2002 03:13 PM
Quick Reply: '91 Truck clutch problem
