91 SR5 doesnt like to go up hill in D
Old 03-20-2014, 05:41 PM
rozz's Avatar
4x4, automatic. Runs well in all other areas. Randomly dies going up small hills and Becoming more frequent in drive. Runs fine in reverse though. When it dies, its hard to start, but get it started and it climbs like a goat and runs fine in reverse. Any ideas?
Old 03-20-2014, 05:50 PM
KirkPayne's Avatar
My truck was doing that, well not that serious. But it could be the fuel pump. That what mine was
Old 03-20-2014, 06:24 PM
rozz's Avatar
It ran fine in reverse? I was thinking along those lines (filter, pump, ect.) But I would think in reverse the symptoms would be the same, not eliminated. Fuel system doesn't care what direction ur going
Old 03-21-2014, 06:31 AM
milkybar's Avatar
Small hill dies: What about larger hills?
Yes trucks don't care what direction, but gravity does.
I'd check Fuel Pump pressure first.
Old 03-25-2014, 09:42 AM
rozz's Avatar
Fuel pump psi is fine... I heard some where about a gizmo in the tranny that might cause it. Searched but can't seem to find. Ideas please
Old 04-03-2014, 10:01 AM
rozz's Avatar
Bueler, Bueler, Bueler...
Old 04-03-2014, 10:54 AM
williscr3's Avatar
its possible the pump will have correct psi at idle but under load it may not be able to keep up with demand. going up hill requires more fuel. have had this problem multiple times on customer vehicles and my own vehicle once. ran good but struggled going up hills or would die out. one way i was able to tell was long starting time, would crank and crank and crank till it started. clogged catalytic converter is also possible problem.
Old 04-09-2014, 01:23 PM
rozz's Avatar
Thank you williscr3, I think I'm going to drop the tank. The only thing Is it did climb in reverse, so that kinda ruled out the pump. The dumb things water pump just went out and overheated now doesn't start (turns over and tries to but no luck).
Old 04-09-2014, 02:10 PM
williscr3's Avatar
well it doesn't entirely rule out fuel pump because it went in reverse. reverse is usually a lower gear ratio, im not sure what it is on these trucks but im sure it is, therefore it wouldnt have a load on the pump.
that doesnt sound good. just a thought, turn the key to the ON position and listen for the fuel pump, or if you have a gauge check it again to verify your no start issue isn't your fuel pump.
good luck.
Old 04-09-2014, 02:23 PM
scope103's Avatar
Check the ignition timing. Check for stored codes.
Zach_trun
11-17-2015 07:56 AM
Obmi
09-16-2015 02:13 PM
longbed
09-16-2015 10:35 AM
noahstancik
09-10-2015 10:47 AM
HookahRoo
07-20-2015 07:06 PM
Quick Reply: 91 SR5 doesnt like to go up hill in D
