89 toyota sr5 ext. cab 4x4 long
Old 07-15-2013, 11:37 AM
hollandhunter's Avatar
I just traded my 86 yota 4x4 and a little boot to a 89 toyota ext cab 4x4. The new one I just bought the 89 is a v6. I have owned several yotas over the years 4x4s and 2x4s but I have never owned a v6 4x4. It is basically stock except it has new off road wheels and tires a navigation system back up camera and a few other fancy gigs. My question do you guys have any watch outs for the year model and make? If so what are they!!!
Old 07-15-2013, 11:40 AM
Fossilized
Staff
dropzone's Avatar
Yep the 3.0 v6 has a ton of issues like head gaskets
Old 07-15-2013, 02:42 PM
Alaska90's Avatar
everyone's experience differs....
i can tell you that i've had my 90 v6 4WD 5SP MAN for the past 23 years. 200,000 miles on it. the only engine work—head gasket via toyota recall LONG time ago, 3 timing belts (and water pumps, pulley, seals since they were in there at the time), a radiator, there was rack/pinon(?) recall at some point, valve adjustments per schedule, set of spark plug wires, dist cap and rotor every 60k, and a alternator. that is it. so far. oh, original clutch but i did do the shifter seat this summer.
i would check with you local dealer and have them run the VIN, see if all the recall work was done.
Old 07-15-2013, 02:56 PM
Thats good advice Alaska90 I will do that. I never thought about calling my dealer and asking them to see if I had any recalls. Cool thanks. will do.
why were the head gaskets such a issue for this yr. Mine has a new one in it by the way. hope it last is about 1yr old.
Nathan_F
08-19-2015 04:03 PM
dirtrider0129
10
06-24-2015 12:24 PM
wagigknp
06-24-2015 12:02 PM
94more
06-19-2015 01:55 PM
Quick Reply: 89 toyota sr5 ext. cab 4x4 long
