89 pickup 22re problems
Old 05-06-2008, 07:23 PM
thisisnttomwyatt's Avatar
hey, my truck is bogging out whenever it gets wet or im in misty weather. i replace plugs plug wires distributer cap and rotor ignition coil and mass airflow sensor and its still being a pain in the ass. ive sprayed most of the parts with water and nothing seems to be arcing out. the boggin only happens in the first 2k rpm area then seems to clear out and run fine afterwards. i have no cat on it and it only happens when wet. i noticed the o2 sensor wires are beat to but would that have anything to do with it? the bogging almost feels like im pushing water through it and then it backfires a few times and clears out around 2k. there isnt any water getting in through the air cleaner though cuz its always wicked dry. anyone had this problem or know what i should try to do? (besides throwing out all the fancy efi stuff and going to a good old fasioned carb)
Old 05-06-2008, 07:31 PM
Flash319's Avatar
The coil probebly has a crack in it around where the wire goes in. Get a new coil. You don't need a Toyota coil, you can get a universal coil from a parts store. Run it at night and look for arcs.
Old 05-06-2008, 07:38 PM
i just got a new coil
Old 05-06-2008, 07:41 PM
and i put some rtv all alround it so it shouldnt have a leak or anything
Old 05-07-2008, 02:39 AM
HAVOC's Avatar
My friend has this same problem. There is a relay in the passenger side kick panel that is getting wet from the windshield leaking.
Might be something to look at.
noahstancik
07-10-2015 11:18 AM
85run
07-08-2015 11:20 PM
bigblue82
10
07-06-2015 08:27 AM
puddlepirate
06-30-2015 05:08 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 89 pickup 22re problems
