88 truck die randomly then runs rough and hardly starts.
Old 10-05-2010, 09:37 AM
wesley4556's Avatar
my 88 truck dies and/or sputters after the check engine light turns on. if it dies it's really hard to start and you have to pump the gas pedal to keep it running. it flashes cel codes 22 42 and 51. these problems all seem related to me. i think it could be a faulty gauge. i took it apart once and the cluster said 86 4 runner so it looks like its from a junk yard. the truck has always done this since i bought it like a year ago. anyone have an idea of whats wrong with it? i replaced the fuel filter because it was clogged, and the starter because i overused it trying to start it all the time.
Old 10-05-2010, 10:08 AM
xxxtreme22r's Avatar
Code 22 Water temperature sensor circuit fault
Code 42 Vehicle speed sensor circuit
Code 51 AC signal on; DL contact off (in trany shifter with diagnostic connector jumped)
I doubt those are related, make sure you don't have an air bubble in the coolant and that the radiator is full, it will run funny if the coolant level is low or if that sensor is bad. It is possible that a leak in the head gasket will cause an air bubble in the coolant system.
I have to assume here this is a 22re since you have not said.
FYI a bad gauge will not trip a cel. nor will it make the engine run funny.
Old 10-05-2010, 12:17 PM
wesley4556's Avatar
its a 22re 5spd 4x4. so do you think i should replace the water temp. sensor?
Old 10-05-2010, 12:20 PM
wesley4556's Avatar
i have checked the antifreeze because someone else told me that could be the problem to.
Yont283
09-23-2022 08:06 PM
puffin04
07-10-2015 09:17 PM
Alex Bessinger
06-28-2015 10:05 AM
sharrack
06-26-2015 09:33 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: 88 truck die randomly then runs rough and hardly starts.
