88-91 3vez swap distributor question
I've put an 88 3vez in to a 92 extended cab. (won't make that mistake again!) I am chasing a massive misfire which I am believing to be a part of the ignition system..
Presently running the 88 distributor, with the rest being 92 electronics. It runs but just barely. In reading the troubleshooting section of the manual, I am learning that the resistance values in the earlier distributors is different...
(this is the first EFI rig I have ever worked on)
Do I need to get a 92 distributor in order for it to work with the rest of the system? And Can the later distributor be machined to fit into the earlier Head?
Your Insight appreciated.
thanks,
Jason
thanks,
Jason
