88 4runner rough idle 550rpms
Old 03-11-2009, 06:58 AM
zachw90's Avatar
Hey everyone. I have an 88 4runner 3.0/ 5 speed with 297,xxx. My trucks been running great until recently, the idle is starting to get rough. Its idling around 550-600 rpms and fluctuating up and down. Ive recently replaces plugs, cap, rotar, however i haven't done the wires yet. Im just looking for some ideas or suggestions, THANKS!
Old 03-11-2009, 08:06 AM
thewjsand's Avatar
You might have a leaking intake gasket. This will get poor air to fuel ratio resulting in a rough idle... Does it change when the truck warms up? if you haven't replaced the gaskets in the last 10 years they are probably dried out.
Old 03-11-2009, 08:26 AM
rdlsz24's Avatar
Also 550-600 is too low of an idle. Try bumping it up to 700 or 800 and see if it smooths out.
Edit: That's what I did with my 22RE. I see you have a 3.0, and I'm not sure what the idle spec is for that engine.
Rob
Old 03-11-2009, 01:41 PM
toyota4x4907's Avatar
How much is it fluctuating up and down?
Have you checked the coolant? The IAC valve is controlled my coolant temperature, so if you don't have enough coolant, it will read it as cold and either idle high or fluctuate.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
musashi86
California SoCal
07-07-2015 03:31 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 88 4runner rough idle 550rpms
