88 4Runner charcoal canister: Purge hose.
Old 02-18-2007, 06:07 PM
Chapman88SR5's Avatar
88 4Runner 3.0
I was under the hood today and I realized a vacuum hose that was unplugged. There are two lines coming off the top of the canister, one that says "to tank" and the other says "purge". I routed the hose back to the "purge" side. When looking at the back of my engine I saw a place to plug it back in and did so. Is that "purge" hose suppose to run to the back of the engine? And what does it do?
Old 07-17-2008, 02:46 PM
4Crawler's Avatar
Originally Posted by Chapman88SR5
88 4Runner 3.0
Yep, to the "Purge" port on the throttle body:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/19.html
Hint: The Purge port has a "P" next to it:
Old 07-17-2008, 10:14 PM
just a 22re's Avatar
really? i might wanna go and check it out then what do the others mean then?
Old 07-17-2008, 10:20 PM
4Crawler's Avatar
The other two are the E and R ports that ultimately hook to the E and R ports of the EGR modulator. The Factory Service Manual has all the information on those. Basically, those ports are just at different locations relative to the throttle plate. So they become active as various throttle positions.
And I labeled both ends of each of my hoses (that is the little white strips on the vacuum lines in the photo above). While those lines may look like a plate of spaghetti at first glance, they are actually very logically laid out and it only takes a little time to understand what each one does and where it goes.
Old 07-17-2008, 10:23 PM
ok that makes since im going to go out and smoke about 50 cigs now cause i bet thats where my power just went lol it was good before the swap and now its just seams funny ill go and take a look real fast thanks a million
p.s. sorry about my French and the hijack but i had to know
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Alex Bessinger
08-31-2015 09:17 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: 88 4Runner charcoal canister: Purge hose.
