87 pickup rough idle
Old 02-03-2008, 03:35 PM
orbit52's Avatar
Hey I have a 87 pickup 22re FI, when I turn it on it idles fine at around 700 to 800 rpms. after it warms up the rpms drop. It will get down to about 400 to 500 rpm idle. the truck runs fine besides that. So far i have replaced the spark plugs and wires, distributor cap, air filter, and ignition coil. I have also sprayed carb cleaner into the throttle body. Was wondering if anyone had any other ideas.
Thanks
Old 02-03-2008, 03:56 PM
TORTIS's Avatar
so is the idle rough, or is the idle just low, or is it rough and low? do you have an ohm meter?
Old 02-03-2008, 04:14 PM
rowdy235's Avatar
Grab a FSM (Or any manual for that matter) and follow the instructions for adjusting the idle. It sounds like somewhere down the line somebody attempted to set the idle (to the warm setting) when the motor was cold, thus, when the motor warms up, the revs drop too low.
I can scan from my haynes manual if you need it.
Old 02-03-2008, 05:07 PM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
I thought my idle was to low .Turns out it was out of timing. Once I timed it it was fine.
Charecter1
11-06-2023 10:08 AM
crashburnoveride
08-28-2015 09:20 PM
Nickdigg
07-07-2015 06:04 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 87 pickup rough idle
