87 4 runner turbo conversion
Old 09-19-2013, 06:08 AM
87runner89's Avatar
Hello I am wanting to put a factory turbo or aftermarket turbo on my 22re. I am pretty mechanically inclined but I don't know what I need to get started and what problems I might have..any opinions??
Old 09-19-2013, 07:32 AM
87runner89's Avatar
Bump...anyone know anything??
Old 09-19-2013, 09:29 AM
longshot454's Avatar
try lcengineering.com they have turbo kits for the 22RE.
Old 09-19-2013, 11:53 AM
wyoming9's Avatar
Red face
There are so many threads on this just do some searching .
your going to do a whole lot of work for very little gain.
Unless your willing to spend several thousand dollars to build a engine you might gain about 35 to 40 horse power
My stock 3.4 will out work my 22rtec any day in fact I am doing a 3.4 swap in the truck i pulled out a 22rtec
also there is a forum for the 22rtec vehicles
Old 09-19-2013, 12:05 PM
osv
osv's Avatar
a turbo install on any motor, you should be able to double your horsepower, but it would take something like megasquirt and a decent intercooler setup, not the factory Toyota stuff.
the last one I did was a bored/stroked vw motor, blow-thru on dual dellortos, what a blast.
you probably don't have to deal with smog, right? sky is the limit.
Old 09-19-2013, 12:21 PM
vasinvictor's Avatar
I guess you gotta start somewhere. Turbo setup are universal in theory in a lot of way. You need to just start researching turbo setups to get a basic idea of what you're in for. Turbo setups can be had for $600 (homebrew and self fab) to thousands and thousand of dollars depending on what your goals are.
Old 09-19-2013, 12:51 PM
Discombobulated's Avatar
Skim over these forums, not as active as here but good info, http://www.22rte-trucks.com/simplemachinesforum/
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 87 4 runner turbo conversion
