86 pickup w/ 22r carb trouble
I had been having trouble with keeping my truck running. Discovered that the carb needed to be rebuilt (it was extremely filthy). Once I put the carb back on the truck, it sounded like it ran fine. Idles at a decent rpm when first started, 600-1000 depending on temperature. However, when the accelerator is pushed it boggs down really bad, to the point that it almost stalls, but only for a few seconds. Once the rpms reach over 2500 the pedal can be pushed all the way to the floor with no hesitation whatsoever. I am guessing the secondaries (sp?) are opening too soon but not sure. All the vaccum lines are routed correctly. Any ideas on what the problem could be? more importantly does anyone know where I can find out how the linkage is supposed to be, maybe i put it back on wrong. Any help would be greatly appreciated.
I would guess that the acceleration pump is not working properly. Open the throttle while looking down the carb and see if fuel squirts in it. If it does not, then your acceleration pump is bad.
It would be a dream to know this issue was resolved. I know this is 10 years old but damn if the description isnt perfect. I'm not sure where to look. But my carb is rebuilt as was my aap.
Can you see fuel squirt when opening the throttle? Even though it is rebuilt, you might have a problem with the new diaphragm/spring, or the check valves in the carb might still be stuck. The accelerator pump linkage could also be worn, so it is not squirting the right amount at the right time. If you are sure the accelerator pump is working properly, re-check all the vacuum lines. There are a few things that start receiving vacuum at partial throttle, and if one of those lines is going to the wrong place it might cause some hesitation. You might even try plugging the vacuum ports temporarily and see if the problem stops. That would rule out vacuum line routing problems.
Sounds to me like a bad vacuum advance on the distributor. I don’t know how to test one but a mechanic I had diagnose my newly rebuilt engine told me mine was not working at all, and it was stumbling on acceleration too. I got a new distributor from Summit Auto. I had just put a new Weber carb on it which has been running great.
Sounds to me like a bad vacuum advance on the distributor. I don’t know how to test one...
Once you've gotten the arm to move, block the vacuum line off, and see how long it holds the little arm in it's "moved" position. The Book doesn't specify a length of time, so just: "will it hold vacuum" is the requirement. If not, you will either need to replace the diaphragm, maybe from a junkyard, or the entire distributor, including the vacuum advance unit, which is still available. Dealerships, and so on, carry it.
Does that help any?
Pat☺
You are correct. When you open the throttle, fuel will squirt into the throat of the carb. It should squirt as soon as the throttle is open. If it squirts, but not until the throttle is partially open, then the linkage might be worn. Also make sure the diaphragm returns properly. I rebuilt a carburetor once and after a few pumps the accelerator pump got stuck and caused the exact hesitation you are describing. I should also clarify this is the for main accelerator pump. The AAP is an Auxiliary Accelerator Pump that is on the opposite side of the carburetor and controlled by vacuum only when the engine is cold.
If I remember correctly, the factory manual specifies various amounts of vacuum to advance the timing a specific number of degrees. Each diaphragm in the vacuum advance is different, and both can vary depending on your smog designation. I basically just make sure both diaphragms hold vacuum and advance the timing smoothly. If you rule out the accelerator pump, then it is worth looking at the distributor for any loose parts or shorts in the pickup coil wiring, and check the air gap.
kawazx636
10-06-2021 03:03 PM
Toys4parts
09-26-2015 01:56 PM
22r, acceleration, carb, carbuartor, forum, fuel, hesitation, linkage, mist, pick, rpm, sight, stumble, toyota, troubleshooting
