86 4runner fuel injector will not fire
Old 10-24-2009, 08:09 AM
va slim's Avatar
im new to these forums, so bare with me, hope im in the correct one. fuel injector harness test good, shorted blue wires for #2 and #4 tootransistor plug and all i good, but #4 still wont fire, but got spark at plug, need some help, getting frustated
Old 10-24-2009, 08:20 AM
abecedarian's Avatar
Grab an ohmmeter and check the injector resistance. can't tell you what the reading should be but you can compare it to the resistance of the other injectors. If it's open or differs from the other injectors by more than a few ohms the injector is probably bad.
Old 10-24-2009, 09:39 AM
va slim's Avatar
ty for the info, but ive moved #2 injector plug too #4 and made #4 start working, leading me to believe it it was in the harness, but thats good, thinking it may be the comp now?
Old 10-24-2009, 10:17 AM
DJ99's Avatar
On my V6 3VZE the manual shows that the groups of injectors for cylinders 1,3,5, and 2.4,6 all get turned on at the same time. One wire out of the ECU for each group. It points to the injector harness at cylinder 2, since you said you tried it at #4 and it worked there.
Old 10-24-2009, 10:21 AM
toyota4x4907's Avatar
nevermind
Old 10-24-2009, 10:29 AM
va slim's Avatar
arent the only wires from comp the 2 grounds, the power wire come from the transistor mounted on the fire wall, i think, i reckon that could be bad,but i have continuity on both blue wires, one for #2 and one for #4 at the transistor plug, am i looking to deep into this, or do just not gett it
Old 10-24-2009, 11:43 AM
jimep's Avatar
as he said- the 22re's are almost the same way. Actually the power wire comes from the ignition to the injector resistor, (if so equipped as ur truck has) that's 1 wire. then 2 wires out to the injectors.. they are batch fired so #1 and 2 should open at once and #3 and 4 should open at another time. there are 2 wires that go from the injectors TO the ECU. The ECU grounds out the connections when told to fire each set of injectors... First I'd plug a noid light in each injector plug and see what happens. that should give an indication if eveything in the wiring harness and ecu is ok or not. If one ore more doesn't flash, when u turn the truck over, break out the voltmeter and see where u loose voltage in that circut by checking it to ground.
Old 10-24-2009, 11:44 AM
DJ99's Avatar
You should probably check out an electrical diagram for your vehicle. On mine, like yours, the grounds come from the ECU, but the power comes directly from the ignition switch. You may have a resistor pack on your firewall, or not. You might be able to open it up and check it out with an ohmeter.
Old 10-24-2009, 11:53 AM
Courtesy of 4Crawler:
Not reflected in the diagram is that the ECU holds the wires at +12v until it's time to fire the injectors at which time it switches its wires to ground during the injector firing event. Meaning that if you plug a voltmeter into each terminal of each injector plug, they should read 12v to ground with the key on. If it doesn't, it's likely an issue between the plug and the splice in the harness since #2 does fire but #4 doesn't.
Old 10-24-2009, 11:58 AM
DJ99's Avatar
So if the power from the resistor pack is split into two for your #2 and #4, and #4 works, then something has to be wrong with the harness one one side or the other.
Old 10-24-2009, 12:00 PM
jimep's Avatar
Ha! beat u to it abe. but u got a pretty pic
Old 10-24-2009, 12:01 PM
va slim's Avatar
ok, im not thinking the right way, ive got one blue wire from resistor that t's, to #2 and #4, so in a nut shell thats the same wire, and #2 works but #4 doesnt and they are all good, so i think im comprehending that yall are saying that the pulse for #4 isnt getting there?and if not, that i should look at either the resistor itself or the ecu, im trying to figure it out guys, little slow though
Old 10-24-2009, 12:03 PM
va slim's Avatar
alright,ill try again
Old 10-24-2009, 12:06 PM
Yeah, you beat me to it.
But although you are correct that the injectors are batch fired, all 4 fire at the same time, for the same duration, once per engine revolution.
So, like I said, if #2 injector plug fires an injector but #4 doesn't, it's a wiring issue, either the splices, the #4 plug or the wires between the splices and the plug.
Old 10-24-2009, 12:09 PM
DJ99's Avatar
It's all good! Don't we all have other things we should be doing?
Old 10-24-2009, 12:13 PM
yup. trying to get my brother to go get the stuff for the BBQ so I can stay here.
Old 10-26-2009, 03:47 AM
va slim's Avatar
hey, i got it. THANKS for the input guys, the metal terminal in the plug was split in two, everytime i pulled plug off to test the terminal would go back together, thus giving a good test, when i put it back on injector, it would open up, thus not making contact, bought new pigtail from autozone and runs like a champ
Old 10-26-2009, 04:26 AM
DJ99's Avatar
That's great work! I'm glad you got it running right again. Thanks for reporting back.
Charecter1
11-06-2023 10:08 AM
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 86 4runner fuel injector will not fire
