86 22RE-T Start Problem For 3 years now HELP !
Old 10-07-2020, 04:59 PM
Co_94_PU's Avatar
Yep 36522, still my daily driver when it's not cold and still needs a ton of body work
Old 10-09-2020, 02:06 PM
shafner30's Avatar
Do u have a aftermarket fuel cap? Or a OEM toyota fuel cap?
Old 10-09-2020, 02:33 PM
pimacdaddy's Avatar
thanks for your reply. OEM and changed it not so long ago. Actually everything I changed is from OEM (or whatever it is) back to OEM
Old 11-17-2020, 01:16 PM
pimacdaddy's Avatar
Thought Id write a little update:
SO I got all injectors rebuilt, flow balanced, new screens o' rings grommets and all that. The cold start injector as well. Still have a pressure leak...
BUT got a bit of progress done, today. I remove the Idle Auxiliary Control Valve and adjusted the opening via the little nut behind it, since I never had high idle on cold starts and its much needed here since winter is coming.
I did swapped the IACV before but never really paid attention to that adjusting screw... First picture is after adjusting and the second one before adjustment.
Also uploading picture of the injectors job;
VIDEO OF TRUCK STARTING AT RUNNING TEMP. WITH NEW PLENUM INTAKE GASKET, EGR GASKET, ALL INJECTORS REBUILT, FUEL RAIL ULTRASONIC CLEANED, FPR TESTED:
Old 11-17-2020, 06:34 PM
  #25
Co_94_PU's Avatar
You might want to do a summary?
That last video was a bit slow, I should say maybe five full cycles before it started and ran, but the starter is cranking pretty fast.
Does it start faster if you shut it off and restart.. Lots of irrelevant questions not going back through the thread.
Old 11-17-2020, 06:43 PM
  #26
pimacdaddy's Avatar
Yeah starts faster if I shut it off and restart it. But after a while even on runnin.temp it feels like its strugglin to start.
Old 12-09-2020, 01:48 PM
  #27
pimacdaddy's Avatar
OK !
SO I GOT MY COLD START ISSUE FIXED UP ! HOORAY ! BUT !!!
I have a LOW/ROUGH Idle after a warm start, like this video. SAME thing
I have the Toyota Service Bulletin VOLUME 10 in front of me thats says to;
Swap Switch Temp. No.2 from 89428-28030 to 89428-26020 and to change Switch, Start Injector Time from 89462-30011 to 89462-20050 (This last one I already did)
BUT My QUESTION IS Where the hell DO I swap the problem of condition 1 ? On my Thermostat housing I do not have that switch.
Old 12-09-2020, 02:44 PM
  #28
Blueman's Avatar
Have you reviewed this thread? It's a similar discussion.
https://www.supraforums.com/threads/...-miles.973577/
Old 12-09-2020, 03:05 PM
  #29
pimacdaddy's Avatar
No I haven't I am now viewing this thread;
https://www.yotatech.com/forums/f116...38/index9.html
It is fairly long with lots of random inputs by various member about different issue. I will take a look after.
UPDATE I DO HAVE THE SWITCH ON THE THERMOSTAT HOUSING ACTUALLY !
Old 12-09-2020, 05:28 PM
  #30
Co_94_PU's Avatar
Yeah that's TSW
Old 12-09-2020, 05:35 PM
  #31
pimacdaddy's Avatar
Yeah I think I will try and source the part, so far nothing is available for the damn thing.
Old 12-12-2020, 01:07 PM
  #32
pimacdaddy's Avatar
Question.
In the bulletin they say that PREVIOUS P/N is 89428-28030 and that the NEW P/N is 89428-26020
I can only find the PREVIOUS P/N online. Says it won't fit my vehicle. Anyways my question is, will the PREVIOUS P/N be the same part as NEW P/N ?
https://www.toyotapartsdeal.com/oem/...;0=RN55L-PGCZA)
A bit confused here. Just don't want to buy a part that will be the same as what is already on the truck. Tired of spending and throwing parts at it.
Old 12-19-2020, 11:08 AM
  #33
pimacdaddy's Avatar
It's a little bit confusing how the NEW P/N 89428-26020 isn't available, but the PREVIOUS P/N 89428-28030 is....
SO IS the PREVIOUS P/N going to be the same part as the NEW P/N ?
At the dealership they said it would be the same part, but just from the bulletin it's a bit confusing.... Any thoughts anyone ?
Old 12-19-2020, 11:11 PM
  #34
Co_94_PU's Avatar
Two things
First your maybe over invested in this tsb fixing your issue without actually testing the system. Check when your TSW closes, check when the VSV switches, bypass the VSV..
Talk to your parts counter rep, odds are neither of these parts are still available from the dealer. There is at least one source of temperature switch that Google should turn up, its been awhile since I looked so I can give you a specific keyword search but it's out there.
... I've never had this issue mine fires just fine regardless of heat soak with the only variable being low cranking amps. When the starter doesn't spin quickly it fires on the first Rev of the crankshaft, if the starter spins quickly it fires a little later, which is due to the fuel pump not having time to pressurize the system.
Old 12-20-2020, 05:24 AM
  #35
pimacdaddy's Avatar
For the record, I do a lot of researching online and offline. I went to the dealership for the 26020 Switch and discontinued. The PREV P/N is $10.33 online, at the dealership it was $245.
I also didn't test the switch because I presume the hot soak problem described in the bulletin is the same problem I have. The engine will shake and stumble badly after a hot soak and the rpm drops If I don't give it gas.
This is pretty much the only part I haven't swapped on this truck. Also the switch will turn 35 years this april. A little refresh could be good for the system. Anyways I did find replacement part number but not absolutely sure;
https://toyotaparts.mcgeorgetoyota.c...nit-8942820050
https://parts.camelbacktoyota.com/oe...nit-8942820050
Wonder if that is the replacement part for 26020.
Old 12-25-2020, 02:41 PM
  #36
87-4runner's Avatar
You said early in the post that a "Toyota " mechanic installed your TPS...
that doesn't mean he knew what he was doing. The TPS HAS TO BE SET PROPERLY...
I'd verify that it is...
If your not comfortable doing it, you can take it off and send the throttle body and OEM TPS to Jerry at 22re performance and he'll set it for you.
GMartin1991
10-02-2020 03:38 PM
Dave co
04-18-2016 11:16 AM
landrunner
08-05-2015 09:18 PM
sworn2funloyal2nun
03-03-2013 09:36 PM
tiger906
11-21-2012 12:24 PM
Quick Reply: 86 22RE-T Start Problem For 3 years now HELP !
