80 AMP fuse trashed
Old Nov 18, 2007 | 05:08 AM
frisbeedog's Avatar
80 AMP fuse trashed
While troubleshooting my alternator/ battery charge light problem I got into a little jam I was ckecking the fuses behind the battery before doing an alternator check following the Haynes Manual. When I got to the 80 amp fuse it looked blown and was difficult to remove. While gently persuading it to let go, all hell broke loose. Now the fuse is in a couple hundred parts with some still in the box. What i'm wondering is:
1. Should this fuse be easily removed like the others? My assumption was that it was toasted to the wires underneath.
2. What would the best method for removal and installation be, at this point?
3. Am I a total nincompoop or what? Nevermind do not answer that..
Oh yeah, It is a 1988 4runner V6. If you guys help me out I will graciously post lots of pics next time.
Old Nov 18, 2007 | 12:47 PM
bleakhorizon's Avatar
if i am correct i belive that fuse is actually bolted in you might wana check right under it and c if there is a nut/bolt
Old Nov 19, 2007 | 04:02 AM
frisbeedog's Avatar
I found the writeup about replacing the wire coming off of the positive battery cable. It had a great picture of the bottom of the fuse box. That's what happens when you drink two cups of coffee and start working on vehicles.
Next step is to replace the alternator bushings to see if this turns off the battery charge light.
Thanks,
Old Nov 19, 2007 | 05:10 AM
SoCal4Running's Avatar
I dont know if the V6 are the same, check the charge fuse. Its in the driverside kickpanel; should be a 15A in the middle on the bottom. Take the cover off and you'll see what I'm saying.
Old Nov 19, 2007 | 05:36 AM
frisbeedog's Avatar
I was looking for that fuse box yesterday. Felt like I was going to rip the crap out of the carpet trying to find it. Is it down to the left of the drivers left foot? Thats were it is on my 2000 Tacoma. But, it was hard to see on the runner.
Old Nov 19, 2007 | 06:00 AM
8yota9's Avatar
i had a problum simmler... my truck(89v6p/u) would randomly die from time to time. i said ok lets see the batt is not charging...ok new batt. crusin fer a lil wile with the new batt and she dies agean .ok thats it im pissed, down to P&A for a new Alt. installed..noice..but once agean she fails.So me and my GFs old man tow the yota to his house were we begin really inspecting it. 2 days and a lotta tinkering around and we found out that the in cab fuse block were the 30Amp alt fuse is wasent makeing proper conection so he shoved a little bold in nexto it and i have never hade this problum agean. morel of the story check the simple things first. check the alt wires for chafing. and that fuse it dose have a bolt throo the bottem of it i riped mine apart getting it out to.
hope this helps a little
Andrew
Old Nov 19, 2007 | 06:16 AM
frisbeedog's Avatar
Yup, that helps alot. I replaced the battery with a new one. Ended up returning that one because the light was still on. So now I'm starting with the little things. Thanks..
I'll check the fuse box this evening. I really need a stupid garage.
Old Nov 19, 2007 | 06:22 AM
8yota9's Avatar
Haha ohh man. im so sick of screwin around in the driveway.i pray everynight that a garage will magickly appear in my yard haha yea right. good luck and get the old carhart out its gettin chilly..
Old Dec 9, 2007 | 06:37 PM
RiNkY's Avatar
Thanks,
Where is said write up? I noticed mine is going bad and the 80 Amp fuse in the relay box is blown now too, which might be as a result of that. Write up would be awesome.
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Tcsdef
Sep 7, 2015 11:17 PM
