4x4 will not engage
Old 12-05-2011, 10:46 AM
90_4x4's Avatar
4x4 will not engage
Hello I'm new here anD my 4wd will not engauge on my 1990. Even when I swap the two vacuum line around on the diff it still doesnt work. Now on the passenger firewall there are the Vsv valves and then after the three in a row valves I also have another right next to them that has vacuum lines that are 3 way connections. I'm assuming vacuum isn't reaching my diff because it didn't engauge when I swapped vac lines. So what is this other valve?
Old 12-05-2011, 11:12 AM
4Crawler's Avatar
http://www.off-road.com/trucks-4x4/t...tem-19259.html
Check for plugged lines and vacuum fittings.
Old 12-07-2011, 12:32 PM
90_4x4's Avatar
Got it all figured out a few vacuum lines were swapped around in the engine bay.
Old 12-07-2011, 12:51 PM
4Crawler's Avatar
Yep, that is the most common problem cause that I have heard. Shop or PO works on engine, disconnects some lines, hooks them back up and engine seems to run fine so they call it good.
westonian18
05-01-2020 06:38 AM
mussy01
12-13-2016 08:20 PM
defrag4
07-31-2015 10:50 AM
tomczaksdiesel
07-26-2015 10:35 PM
jgwerth
07-16-2015 03:23 PM
Quick Reply: 4x4 will not engage
