4wd Binding - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-20-2008, 09:45 PM   #1 (permalink)
Crawdad's Avatar
4wd Binding
Hi, I just bought a 1990 4Runner SR5 4wd, with the v6. It runs great, and everything on it seems solid, except one thing. While testing the 4wd today (to make sure it engaged) on dry pavement (again, I know this is bad - I was just checking to make sure it worked), just driving straight forward 10-20 feet, the drivetrain started to bind. When I say bind, I mean it would buck a little - not enough to keep it from moving. Now, I'm not incredibily familiar with 4wd, but this is my 3rd 4wd vehicle - I used to own a Dodge Durango, and I currently own a Dodge Ramcharger on 36" TSLs. The Durango didn't bind unless at full turning lock, but it had cushy electronically-compensated everything. The Ramcharger I wouldn't be able to feel if it bound anyway.
I took it offroad today and it ran fine, but I noticed that the front wheels seemed to be "slipping" while I was driving - that is, every 10-20 feet they would rotate and slip a little bit, especially while turning. There wasn't really enough of a straight shot to try it out just going forward. It was not noticeable by anything but the sound, though.
Does this sound like normal drivetrain stuff, or should I be checking to see if the differentials have been regeared? I know that you can check them by noting the number of times the wheels turn in relation to the driveshaft, but I'm not too familiar beyond that.
By the way, if it's of any consequence, the front tires are slightly more worn (1/4" or so) than the rear, and I haven't checked tire pressure, but the front tires need more air in them, they "pooch" more than the rear ones.
Crawdad is offline
Old 04-20-2008, 09:51 PM   #2 (permalink)
Matt16's Avatar
You're on the right track, that is not normal. I can drive on rainy roads for a while in 4wd and it doesn't bind much. I don't do it often unless for some reason I feel I need to.
A quarter inch might be enough, enough but I doubt that a bit. You could eliminate that possibility by rotating one of the front tires to the back.
It is quite possible someone stupid got the wrong ratio if they picked the diff up from a wrecker.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 04-20-2008, 10:13 PM   #3 (permalink)
Crawdad's Avatar
Just checked tire pressures before I turn in for the night - pass side front is at 23ish PSI, the rest are in the neighborhood of 31psi. I didn't add any air yet, as my neighbors LOVE my compressor during the day, and I'm sure they'll love it twice as much at midnight.
Ran it in the grass for a few feet, didn't bind but it "clunked" when I shifted from 4h to 2hi.
Beginning to regret my purchase.
Edit: Is there any way to check the ratios from a stamp or casting on the housing/third members?
Crawdad is offline
Old 04-20-2008, 10:58 PM   #4 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
There's an axle code on the VIN plate. Search here or google axle codes or Toyota axle codes for deciphering.
The tire slippage could be very normal. The vehicle has open differentials and so one tire will slip.....especially in a turn.
The clunk...I've heard other people report that as being normal on 5spd. I can tell you on my auto V6 there is none. Have you check the fluid levels and inspected the drivetrain for play at all? U-joint, connecting flanges, etc.
The binding, I don't know. I guess I'd have to hear it. Sorry. Neither of my Yota 4wds's (also have a 5spd, 4cyl) bind in a straight path, though.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 04-21-2008, 05:27 AM   #5 (permalink)
dirtoyboy's Avatar
IF someone swapped the diffs the VIN code is useless to determine what they are. Manual verification is the only way. The tires slipping and bucking on road sounds like 2 different ratios to me
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 04-21-2008, 06:09 AM   #6 (permalink)
Crawdad's Avatar
Quote:
What I figured. Aside from pulling the thirds out and counting the teeth on the ring gear, is there any other way to check the ratios front and rear? And assuming that they are mismatched, how difficult of a process is it to swap out the thirds? I'm more familiar with Dodge/Dana axles (familiar enough to know not to touch them, anyway).
Crawdad is offline
Old 04-21-2008, 06:25 AM   #7 (permalink)
dirtoyboy's Avatar
Quote:
easy peasy....jack the vehicle up and count the number of driveshaft rotations to wheel rotations.
__________________
Old 04-21-2008, 06:44 AM   #8 (permalink)
Crawdad's Avatar
Let's assume for a minute that the ratios are different and I know which ratio I want. It it possible to switch 3rds relatively easily, and how difficult is it going to be to find one?
Crawdad is offline
Old 04-21-2008, 06:52 AM   #9 (permalink)
dirtoyboy's Avatar
Or I could just run this thing off a cliff and forget I ever bought it
Switching 3rds is easy! Probably a 3 to 4 beer job at most with common hand tools, no experience and a good service manual. Don't be scared if you have to do this at all
__________________
Old 04-21-2008, 06:57 AM   #10 (permalink)
07sbock's Avatar
Send a message via AIM to 07sbock
Do you have a feeling when you bought your runner that it had been "molested"? On my old 95 4runner it only clunked into 4x4 if you had the engine revved. I dont know about the binding, check you cv shafts. Do you have the matinence history on it?
__________________
1998 4runner Limited, Locker,Black Headlights, Sport Hood,99 suspension, more to come!
2000 Ford F250 7.3 Diesel, plow and yard service truck
1999 Ford F350 6.8 V10 Dump Truck
2007 Yamma Grizzly 700 FI, Warn 2500 winch, 54" Snow Plow
07sbock is offline
Old 04-21-2008, 07:09 AM   #11 (permalink)
Crawdad's Avatar
Quote:
Ha, a little bit. I bought it from my father in law for next to nothing (under $1k), and I know that he recently had the rear diff replaced because it was noisy. Before that, I'm not sure who owned it, but I don't think that it has ever really been offroad. I'm going to ask my FIL about it tonight and see what info he has.
Crawdad is offline
Old 04-21-2008, 07:12 AM   #12 (permalink)
dirtoyboy's Avatar
Let us know! I'm willing to bet thats the problem right there!
__________________
Old 04-21-2008, 10:41 AM   #13 (permalink)
grant526's Avatar
Don't assume the worst. The previous owner may not have rotated the tires often enough. So they are worn to different diameters, creating a gearing difference. Try rotating the tires to the other end. Usually the front end wants to be slightly higher geared [a hundreth (.01)or 2 (.02) higher] then the rear, so it pulls instead of getting pushed. Unevenly worn tires can create enough difference to break gears in the diff.
If your ratio's are different, you more-than-likely would have broken the higher ratio gears by running it as much as you have already.
__________________
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
Lincoln Locked in the rear; running 5.29s
DD's: '87 XJ and '91 Suzuki DR650s
Wheel Responsibly, Don't screw it up for the rest of Us. . .
"Obama is an acronym.
OBAMA = One Big Ass Mistake, America" - Thanks for the Quote Hayes
grant526 is offline
Old 04-21-2008, 10:45 AM   #14 (permalink)
Matt16's Avatar
Bingo. Thirds are about $150 from a wrecker. It would be easy enough to pick up the wrong ratio.
__________________
Toyota FAQ link
Matt16 is offline
Old 04-21-2008, 01:02 PM   #15 (permalink)
Crawdad's Avatar
I'm really hoping that this is the case - the previous owner has been working on Toyotas for many, many years, owns a 4runner and about 4 other Toyotas, so I don't think that the mixup was done by him. The rear suspension is way out of alignment, in that the tires are bald on the inside, and have 1/4" tread on the other side. The front tires are pretty evenly worn, but are nearly bald. And one of them is about 10psi lower than the other three. I'm going to air the tires up better tonight, and then swap them around and see what I can figure out.
It seems to me that if the gears were vastly different ratio, it wouldn't be able to really drive in 4wd. As it is, you can ride the thing down the road in 4hi, it just doesn't sound good. Or feel good.
If they ARE mismatched, I'm going to have fun trying to distinguish 4.1 turns of the wheel from 4.3 or 4.8
Crawdad is offline
Old 04-21-2008, 01:37 PM   #16 (permalink)
Thumbs up
Yup - gut instinct says gear mismatch
Its pretty easy to tell- even the difference between 3.91, 4.10, 4.30
3.91 - just shy of 4 complete turns
4.10 - more than 4 but less than 4-1/4
4.30 - more than 4-1/4 but less than 4-1/2
4.56 - just over 4-1/2
I always physically, manually verify gear ratios via spin & count method or count.
Here are some stories.
Friend bought a used 4wd Tacoma - THe Orig owner (very meticulous) bought a complete assembled LSD rear diff from the toyota dealership- He gave them VIN # and even told them he had 4.10's.
Dealership sold him a 3.91 Diff.
Even one of the Yotatech sponsors worked out a deal on what he was told were 4.10 E-locker complete rear diff & axles. His Toyota Supplier Sent him about 30 4.30 complete e-locked rear axles.
GrillmasterP is offline
Old 04-21-2008, 05:59 PM   #17 (permalink)
Crawdad's Avatar
Here's what I did:
Jacked up the rear end on one side - one tire up, one tire on pavement. Chalked the tire, chalked the pavement. Chalked diff housing, chalked driveshaft. Rotated tire 2 full revolutions. Driveshaft rotated just over 4.5 times. 4.56 gears?
Did the same for the front - rotated tire 2 times, driveshaft rotated just over 4 times. 4.10 gears?
Here is my question: I would LIKE to keep the 4.56 gears, since they are taller and I plan on lifting and going to 33"s. However, it seems to me like the front third member would be an absolute pain in the butt to replace. Also, I remember reading that the 1990 front diff is different (has ADD?) than others. Will I HAVE to replace it with a 1990 3rd?
Anyone have a 4.56 front third they wanna sell?
Also, since I wheeled it very briefly like this (15 minutes or so), and rolled it back and forth on the street a while, what are the odds I blew my transfer case up? Heh.
Crawdad is offline
Old 04-21-2008, 06:24 PM   #18 (permalink)
black diamond's Avatar
drive shaft revolutions arn't always that accurate.. did u drain the front diff and check for metal? ring gear?
black diamond is offline
Old 04-21-2008, 06:28 PM   #19 (permalink)
Crawdad's Avatar
Quote:
I haven't yet. The PO insists that when he replaced the chunk, he put 4.10s in it, because he matched the gears he bought off the door code. I'm inclined to believe him since he's been doing this for forever, and knows more about Toyotas than anyone I've ever met.
I guess the only way to check is to pull the dang chunk out of the rear and count the teeth on the ring gear.
Would low t-case fluid cause anything like this? I haven't checked yet, just throwing that in the mix.
Crawdad is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
CV's Binding?! Nate08 95.5-2004 Tacomas & 96-2002 4Runners 25 12-04-2007 12:05 PM
4WD seems to be binding? AE86GTS 86-95 Trucks & 4Runners 42 11-10-2007 12:08 PM
Binding in front end. Help please. mysubaruimp 95.5-2004 Tacomas & 96-2002 4Runners 15 04-16-2007 09:55 AM
Binding brakes on Hilux frik General Vehicle Related Topics (Non Year Related) 4 01-13-2006 06:18 PM
Spark plug binding My99 95.5-2004 Tacomas & 96-2002 4Runners 5 07-06-2004 12:33 AM
2009 InternetBrands, Inc.
