4Runner tail light covers?
Old Nov 18, 2007 | 06:50 PM
WCorbett's Avatar
How do I get the tail light cover off to replace a bulb on my 91 4runner? I looked all over the cover for screws and there are none. Anyone know?
Old Nov 20, 2007 | 04:20 PM
Tempy T4R's Avatar
Open the tail gate - there are 2 10mm bolts by the on the inside of the tail lights. Undo these and gently pry the whole lens assembly towards the outside - there are little round metal connectors that sometimes seize/corrode into the lense - if you pry too hard you will crack the lens.
you will feel them come undone - and the harness assy can be seen going into the rear of the lens assy. you can now twist the bulbs out!
Hope that helps....couldn't find any pics to show you.
Good luck!
Old Nov 26, 2007 | 04:25 PM
WCorbett's Avatar
Are you sure because ive looked on the inside with the tail gate open and couldnt find anything.
Old Nov 27, 2007 | 02:03 PM
leebee's Avatar
the bolts should be on either side of the two piece stay the holds the gate from dropping all the way down.
lee
Old Nov 27, 2007 | 04:19 PM
WCorbett's Avatar
Alright thanks i got it.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
