4Runner on 33x10.5, Gear Options?
Old 06-28-2007, 08:51 AM
mt_goat's Avatar
Originally Posted by run4her
I have a auto 4runner on 35's withe a true track in front and a spool in the rear and i only have 529's. i have plenty of power.
How often do you get to use OD with that? Because when you are talking gearing on an auto tranny most people are really talking about the top gear (OD) and being able to stay in it into a slight hill or head wind. Yeah if you don't mind using the lower 3 gears all the time then you can get by with less than optimum gearing. With the 3.slo/auto combo and 33" tires I've run 4.88s, 5.29s, and 5.71s and I found the best combo to be 5.71s in just about any daily driving situation, including 80mph down the interstate. Oh of course 5.71s are better on the trails too.
Old 06-28-2007, 11:15 AM
tc
tc's Avatar
It was a manual. While a couple hundred RPM change doesn't seem like much, with our motors the difference in being in the power band and not is so extreme that it makes a big difference in drivability!
Old 06-28-2007, 12:52 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
So, with a 31x10.50" tire, 3.0, and A/T, would 5.29 gearing be adequate for hauling and towing. Or do you think 5.71's would be better?
Old 06-28-2007, 02:13 PM
tc
tc's Avatar
5.29 would be good with 31's and auto. You may actually be able to use the OD on occassion (not while towing of course!)
Old 06-28-2007, 02:50 PM
  #25
drock2's Avatar
Appreciate all the info, it's a big help.
Originally Posted by tc
Your 4.88 diffs are not regearable. You're gonna have to buy entire third members (would be a good time to do an elocker!)
That's unfortunate to hear but I would like a locker... Is my 3rd member intechangeable with another Toyota truck, I really wasn't looking to spend a ton of cash?
Old 06-28-2007, 03:15 PM
  #26
ZUK
ZUK's Avatar
Yes...your rear 3rd is inter-changeable with many truck 3rds....all the older 4 cylinder 3rds from 79~95....and the 87~95 "V6" 3rds will work just fine.
Your rear factory 488 3rd cannot be re-geared with after-market gears due to the mentioned reason of closer pinion offset. But it is worth something on Ebay or the FOR SALE bulletin boards. The front IFS carrier CAN be re-geared for whatever you choose though.
I ran 33"x10.50 tires and 571 gears in my 87 Runner with 22RE/auto and thoroughly enjoyed that decision. 3300 rpm on the freeway at 75 real miles per hour per GPS readings. Torque was nice and snappy off the line even with the little 22RE. If I had to do it again, it would still be 571 gears with that engine/tranny combo.
I also had an 88 Runner....3.0 liter and automatic with 31x 10.50 tires....529 gears. It was very quick off the line...especially with the fiberglass top off. The overall gear ratio was in the same ballpark as the 87 Runner with the 31"/571 combo so again, I was pretty happy. You could do 31" tires and 571 gears on your 3.0....but it won't quite be right on the highway at 75 miles per hour. But then again, some people never have that kind of highway use in mind so it could be the ticket for them.
Old 06-28-2007, 04:20 PM
  #27
drock2's Avatar
So all I would have to do is buy a 3rd off one of the vehicles stated above, put 5.71's in it and bolt it up to my axle housing? Would it be a problem if I left the IFS gears stock?
Old 06-28-2007, 04:32 PM
  #28
mt_goat's Avatar
If you want to use 4wd you need to regear the front too.
Old 06-28-2007, 04:58 PM
  #29
ZUK
ZUK's Avatar
Yes, you can leave it stock....just don't plan on using 4WD like mt_goat says. Some people that I set gears up for do just that....leave the front alone for awhile and see if they like the gears in the rear.
Old 06-29-2007, 07:44 PM
  #30
drock2's Avatar
So, this third would be an option:
https://www.yotatech.com/forums/f11/...4-56-a-119089/
or this one:
https://www.yotatech.com/forums/f11/...member-119165/
I'm not sure if my dif is 8"?
Old 06-29-2007, 07:47 PM
  #31
tc
tc's Avatar
Your rear is the Toy 8", front is the Toy IFS (7.5")
Old 06-30-2007, 04:24 AM
  #32
mt_goat's Avatar
or this one:
Yeah, those look good, I'd go for a V6 one because they are a little stronger gears. Or you can buy 3rds already setup with the gears and locker you want.
Zuk may have some on hand. http://www.gearinstalls.com/
mskalmus
05-28-2017 07:51 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 4Runner on 33x10.5, Gear Options?
