3zve engine / vacuum question
Old 02-10-2010, 02:43 PM
MB4runner's Avatar
Hi guys, my truck is an 88, the motor is apparently out of a 95. It's a 3zve.
Are these vacuum hoses correct? I get the feeling the one with the cap should have a hose.
Also, my TPS seems to be on 180 degrees different than other 3zve's I've seen. Yet there is no room for it to be on the opposite side. And the part I circled hits the TPS.
So I'm totally lost whats going on with this motor. Please give me your advice!!
Old 02-11-2010, 03:53 AM
buckz6319's Avatar
not correct ...the one at the rear(by it's self) needs to be swaped with the one with the black cap...I'll double chack mine totay for ya
Old 02-11-2010, 05:40 AM
MB4runner's Avatar
Thank you, thats what I thought, I just wanted to confirm it with another person with the same motor. (And I see you have a 95 auto v6 so thats perfect). Thanks!
Old 02-11-2010, 08:06 AM
buckz6319's Avatar
your welcome
Old 02-11-2010, 09:00 AM
OutlawMike's Avatar
There were several iterations of throttle body design for the 3VZE. Some have the TPS flipped around, like yours. Some have that dash pot above the TPS, like yours. Mine has neither, it is an '89.
Not sure on the vacuum line. Mine has a line connected to it, but I do not have a good picture of where that line connects on the other end. Picture below.
Old 02-11-2010, 10:27 AM
MB4runner's Avatar
Thanks for the input OutlawMike, I think that explains it. The motor and throttle body is out of a 1995, but the TPS is mounted in the "stock" position of the 1988 4runner. So it's really not meant to be that way.
This all makes me wonder what else is weird on my truck. I'm only getting 9 mpg so I've been trying to figure things out and what could be causing it.
kazuya2416
04-05-2024 02:17 AM
smthwsn357
12-04-2023 02:08 AM
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: 3zve engine / vacuum question
