3vzetop end rebuild
Old 11-12-2009, 02:39 PM
bbcrawl's Avatar
3vzetop end rebuild
took the leap and decided that the 2g's a shop wants to do a HG ob is just out of my budget and not worth it for what i want to do with this truck.plans are to do this HG SAS it and get some chevies in the rear. and thanks to morphine for his write up gave me confidence to break into this bitch of an engine.....
on with the tech and pictures.
everything marked with marking compound
getting ready
intake union off
fuel rails
picture of pvc valve hose location FSM dosent give a good pic of were it actually is
coolant temp sensor and others
Old 11-12-2009, 02:40 PM
bbcrawl's Avatar
more of what ive done.
*NOTE* you dont need the SST to get the pully bolt off. its on there extremely tight so what i did was put it in 5th gear and pull the eergency break and used a 3 foot piece of DOM slid over the socket wrench and cranked on it. make sure you put the engine back to TDC if it moves.
intake off
heads off
right bank cylinders # 1, 3, and 5
left bank cylinders # 2, 4, 6....you can see my HG failure was on cyl. number 6 the combusting coolant "cleaned" the piston head
Old 11-12-2009, 02:50 PM
bbcrawl's Avatar
and off to the machine
sent them out today for a valve job(grind valves re-shim) and some milling to make them true flat again.
ill post more pictures as it comes back together and i start with the water pump and timing kit...im also puttin on a new knock sensor wire and new head bolts
Old 12-12-2009, 02:38 PM
calipatient's Avatar
nice... any follow up?
Old 12-12-2009, 02:52 PM
wii_tarded's Avatar
I would recommend replacing the dummy water pump if the one that came off is feeling a little tight or wobbles from side to side. You already have it off, see if you can find one in a jy, to replace it with. That part is $700+ here, and a PITA to replace any other time.
Old 12-12-2009, 03:05 PM
paranoid56's Avatar
are you going to go with arp studs or or reuse the head bolts? i have been told that the stock head bolts are part of the issues we have with this engine.
Old 12-13-2009, 09:23 AM
Tubbyfatty's Avatar
If you reuse the stock head bolts, you shouldnt be wrenching. They are a torque to yeild bolt, so they stretch. Its like 35 ft lbs then you turn em 180*
great job so far. My HG blew the other week and I have yet to work on it yet. Im gonna be following this.
Old 12-13-2009, 10:18 AM
paranoid56's Avatar
sorry, i should have stated that differently. not reusing, but using new head bolts. i read a few places that one of the issues is that they are not up to the task and that studs seem to hold up much better and dont seem to have the HG issues anymore. (this is all internet talk so i guess take that with a grain of salt , i was just wondering )
Old 12-13-2009, 10:32 AM
Tubbyfatty's Avatar
Ive never seen studs. Ive seen ARP head bolts, i think they might of been called studs but they looked like regular bolts to me. Got a link?
On ARP's site i only see the supra motors for studs. no 3vz
Old 12-13-2009, 10:44 AM
area1509's Avatar
Thats the same thing mine did, is there any way to reroute the exhaust away from the heads to prevent this?
Old 12-13-2009, 11:41 AM
camo31_10.50's Avatar
yep...have your shop weld up a BOLT ON crossover that runs under your tranny...unless you go offroad..then have em route it under the t-case output it'll be protected there
Old 12-13-2009, 11:47 AM
area1509's Avatar
Do you have any pictures of how you routed the rite bank down by the starter?
Old 12-13-2009, 11:49 AM
who me?? lol i haven't gotten my exhaust done yet on my 3VZ (gonna wait till after i get the motor rebuilt lol)..
Old 12-13-2009, 01:56 PM
BoostinChick's Avatar
*PCV
Positive Crankcase Ventilation
Will be following this thread too since I will be removing my heads after the winter (no compression #3). Were you doing this on a budget? Seems a popular pair for people re-doing their head gasket is o/s valves and cams.
Old 12-14-2009, 08:58 PM
paranoid56's Avatar
DOA racing engines are the guys i was thinking about
Old 12-14-2009, 10:03 PM
Tubbyfatty's Avatar
Oh gotcha.
Old 12-15-2009, 07:28 AM
Wrenchinjoe's Avatar
What kind of head gaskets are best when you reassemble? Should you go with OEM or does another maufacturer make a better gasket? I have read that copper HGs are a good way to go, but they come in a wide variety of thicknessess, which should you use?
Thanks,
WJ
Old 12-15-2009, 07:54 AM
Go with OEM. If you are getting the heads and the block resurfaced that you should go with the copper/multilayer HG.
bigjstang
08-25-2021 12:41 AM
young buck
18
08-27-2018 02:40 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
dumpster84
04-30-2016 06:03 AM
calderp
07-27-2015 09:58 AM
Quick Reply: 3vzetop end rebuild
