3vze TPS voltage check VTA-E2.
Hi,
So I'm messing with my TPS and the IDL-E2 works properly but the VTA-E2 resistance check is off. The FSM range for the VTA-E2 test is "0.47 - 6.1kOhm" Its my understanding that that means 470 Ohms to 6100 Ohms. Or does it mean 0.47 Ohms to 6100 Ohms? My VTA-E2 resistance is 29 Ohms. Does that mean I need a new TPS? At WOT it is in the recommended range. It does not drop the rpms when I put the jumper in from TE1 to E1. The timing wanders around 10 deg BTDC +/- 1 deg.
If the TPS is OK, what should I check next?
Thanks!
Paul
Thanks!
Paul
06072009, 33, 3vze, adjustmant, adjustment, advance, check, code, range, resistance, sequence, spark, toyota, tps, voltage
