3vze Timing Belt component list
I just need a list of parts to replace while I'm doing my timing belt. My water pump just started leaking so I'm replacing the belt while I'm at it...it would be stupid not too.
Anyway, here is what I am thinking so far.
Timing belt
Tensioners
Waterpump
Thermostat
Cam seals
Front main seal
Anything else?
Timing belt
Tensioners
Waterpump
Thermostat
Cam seals
Front main seal
Anything else?
Idler pulleys (although perhaps that is what you meant by tensioners).
Accessory belts
Radiator hoses
Coolant
Don't know if I'd mess with the cam seals unless they showed signs of seepage. The cam pulley bolts are a real PITA to break loose.
You already have to remove the crank pulley bolt, so the front main seal is easy and cheap to replace at that point.
Accessory belts
Radiator hoses
Coolant
