3vze, gassy oil?
Old 03-11-2009, 08:41 PM
wbthornton88's Avatar
3vze, gassy oil?
Checked my oil yesterday and noticed the stick smelled rather fuelly, any ideas what could be causing this? Also the truck has been running funny bucking and what not. Code readings are 52 and 25.
Old 03-11-2009, 09:08 PM
82stock's Avatar
I think the codes mean knock sensor or it's wiring. The gas in the oil? valve guides? Dead cylinders? I don't realy know.
Old 03-11-2009, 09:27 PM
alright thx
Old 03-12-2009, 10:16 AM
space-junk's Avatar
oh abeypoo...
your assistance is needed...
Old 03-17-2009, 06:51 PM
stormin94's Avatar
Is it at all possible that it smells like gas because it has a million miles?
Old 03-18-2009, 04:07 PM
Catlin's Avatar
Sounds like it is running rich, but the 25 code says your air-fuel ratio is too lean. Is black smoke coming out? Check your air flow meter anyway. If its not opening properly,your car will idle but buck or about shut down when you drive it, and it will make your plugs sooty. It will also make your oil black and gassy. 52 is knock sensor code, one tough job to tackle.
Old 03-18-2009, 04:43 PM
needsomecam's Avatar
not really, remove the upper and lower plenum and have at it
SubiKing
08-21-2021 03:57 AM
jashoeuh
11-26-2017 07:01 AM
clok
08-01-2015 09:42 PM
91yotapup
07-27-2015 07:19 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: 3vze, gassy oil?
