3VZ-E Timing Belt Replacement check
Old 09-08-2011, 03:00 PM
justhop's Avatar
I've just replaced the timing belt and components on my truck, and I was wondering if it would be ok to start up the truck without the radiatior, fan, or any of the other drive belts on there just for a few seconds so I can make sure the timing is all fine tuned.
Old 09-08-2011, 03:11 PM
BMcEL's Avatar
Yep...I wouldn't run it for more than about 30 seconds though.
Old 09-08-2011, 04:41 PM
justhop's Avatar
so all the timing marks seem to be dead on, the truck is running good but is idling at about 1500rpm.....do i need to play around with the timing a little more or could anything else be causing it to idle high?
Old 09-08-2011, 04:49 PM
TNRabbit's Avatar
Well; it's COLD....it will idle high until it warms up. Normal. You can worry about exact timing & idle set later. You're only concerns now are timing belt alignment & no missing~
BMcEL's Avatar
There's no warm coolant running past the coolant temp sensor so it's probably just doing the normal cold idle-up.
Old 09-08-2011, 04:50 PM
BMcEL's Avatar
Ya beat me.
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 3VZ-E Timing Belt Replacement check
