3VZ-E rev limiter?
Old 03-03-2010, 08:31 AM
  #41
Seanwain's Avatar
my 91 seems to loose most of its power after 4200-4500 rpms
Old 03-03-2010, 08:44 AM
  #42
ozziesironmanoffroad's Avatar
know whats weird... last time i was up in the 5k+ range with my 22re, it seemed to have all the power in the world.. was doing 85 going uphill and still accelerating! step on the gas at those rpms and it just shoots forward with no hesitation. after i did that run, it ran GREAT! guess i had to blow the gunk out of the motor. ...though the idle adjustment screw on the throttle body flew out and i drove around for a week with a bolt jammed in there LOL. so i dont reccomend doin what i did. i think on my 22re ive hit maybe 6600rpm? i know it was something crazy like that, the RPM needle almost hit the the bottom of the cluster, but when i get it back im not gonna try it again just to see what it was.
Old 03-04-2010, 11:17 AM
  #43
Ilovemountains's Avatar
I used to click my ECT "power" button and run it up to 5k or so, that was pre head gasket failure, now that I had my head gaskets replaced I keep it under 4k!! I think if you have headers revving higher would be safer because you don't have the ridiculous cross over exhaust manifold blowing all of the gasses from 3 cyls up into the other side then out the back... I cant wait to get my Thorleys installed, they are still in the " ceramic coating stage " according to the MFG.. Its been over a month!! Running at those kind of RPMS Id be afraid of blowing something... again
Old 03-04-2010, 11:41 AM
  #44
broncrider's Avatar
Originally Posted by Volcom
Ever heard of floating a valve?? Revving an engine with no load on it is very bad for the engine. They aren't made to be revved that high with no load.
https://www.yotatech.com/forums/f2/5...ng-soon-77718/
"A high-rpm engine condition in which the valve lifters lose contact with the cam lobes because the valve springs are not strong enough to overcome the momentum of the various valve train components. The onset of valve float prevents higher-rpm operation. Extended periods of valve float will damage the valve train."
I know the valve float had my ranger with the 2.3 they float around 6400 during a power brake but not to sure on my little yota yet. wasn't road worth yet before i moved once again
Old 06-11-2013, 05:32 PM
  #45
ThatGuy1295's Avatar
Why dont you explain to us why its different for the motor to rev with, and without a load?
Old 06-12-2013, 03:44 AM
  #46
Bumpin' Yota's Avatar
Valve float has NOTHING to do with engine load and everything to do with moments of inertia and wether or not the valve springs are sufficiently strong enough to over come the moment of inertia of the valve.
Old 08-30-2013, 10:38 AM
  #47
934RunnerPR's Avatar
not really, 22re, 3vz e rev limiter is set by Toyota at 6250 rpm
Old 08-30-2013, 01:10 PM
  #48
MudHippy's Avatar
Got any documentation, or other type of proof, to back that up?
I can hold my 88 3VZ-E at 6500 rpm steady(without hitting the rev limiter). So I know for certain it's higher than that on mine.
Maybe we're all just trippin'...
Originally Posted by Jay351
I think there is a rev limiter, close to 7k rpm. I know I have taken mine to 6500rpm a few times. Its good to rev it up there every so often, blow all the crap out
Originally Posted by MudHippy
Anyway the rev limiter on mine is above 7000, somewhere between there and 8000. It's below 8000 though from what I can tell, the needle's hard to judge when it's bouncing around up there.
Originally Posted by Bumpin' Yota
ditto - ive had my 3vze DEEP into the 6k rpm region without hitting any kind of limiter. (Accidentially)
Though I HIGHLY doubt we are.
Old 09-06-2013, 06:52 AM
  #49
hey if you want to se the rev limiter on my T4R go here http://m.youtube.com/watch?v=1KS2hlXsynE i uploaded it.
Yeah its my first comment or post but Im pretty sure of what i say
Old 09-06-2013, 07:54 AM
  #50
MudHippy's Avatar
Granted that I'll accept that as proof, it still doesn't prove the entirety of your previous statement. It would only prove that your 93 3VZ-E reaches what might appear to be the rev limiter @ ~6250 rpm. It would also prove your extreme naivety about the 2 Toyota engines of which you spoke. Since what you obviously don't know is...
1. A 22R-E is not a 3VZ-E. What applies to one, MOST CERTAINLY DOES NOT APPLY TO THE OTHER.
2. 92-95 3VZ-E ≠ 89-91 3VZ-E ≠ 88 3VZ-E.
3. Namely, the ECUs are not the same for 92-95 and 89-91 and 88. All 3 versions have different ECUs than the other versions.
4. The very likely difference in rev limiters between the 3 versions becomes very apparent when you read this entire thread from beginning to end. Given that the statements made resemble the truth. They would suggest that the 88 might have the highest rev limiter. The 89-91 might have the next highest. And the 92-95 might have the lowest.
5. You'd better know your Toyota trucks pretty damn good and thorough before you try to argue with me about them.
6. From the sounds of it, you shouldn't be so sure of yourself.
Old 09-06-2013, 05:10 PM
  #51
No problem guess my age... il post some vids of my rig, Burnouts and stuff , Btw ecu is 1992 due to major Wiring fire :/
Old 02-28-2014, 09:27 AM
  #52
az_eaglescout_pilot's Avatar
Thread resurrection!!! 4wheeling last weekend P accidentally had my 88 3vze up to 7000 rpm when i high centered her haha...id rather not do that again...anyone have experience with any aftermarket options for rev limiters out there for toyota?
pic for the heck of it:
Old 02-28-2014, 07:37 PM
  #53
Inu
Inu's Avatar
Wish I could bypass my limiter. I keep bumping it lately at 6200 ish for a 95 auto... any ideas besides after market ecu?
Old 03-07-2014, 08:00 PM
  #54
You could try draining the oil and running it. Oh I assume you want to ruin it right?
Old 03-07-2014, 08:13 PM
  #55
Inu
Inu's Avatar
No valve float and still useable power. If the rod says hi then so be it. Oh by the way my aluminum gaurd is still doing great.
Old 03-07-2014, 08:18 PM
  #56
Thats because you have a rev limiter. And the aluminum guard will last forever until you actually bash it on something.
Old 03-24-2018, 07:20 PM
  #57
YOUNGIAM's Avatar
I bounce mine off the rev limiter at 6500 daily seems to like it. 220,000 miles/ Frank loves it.
Davebarbier
11-03-2015 03:28 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
shredder4286
10-01-2015 01:09 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: 3VZ-E rev limiter?
