33-12.50's????
Old 04-09-2007, 07:15 PM
1989toy4wd's Avatar
33-12.50's????
Okay, my truck has a 2 in lift (blocks t-bar crank), and I was wondering if i could fit 33-12.5 15s on my truck?? I know as a fact I can fit the 10.50s with stock height, but what about the 12.50s!
Also, how much more gutless would it be, I know its not a racecar, I just want to be able to pull up bridges and stuff, not to worried about hills or anything like that, cause there is nothing like that around here besides overpasses!!
And finally how much would my speedometer be off ??
Im sure this question has been asked a couple of times, but I couldnt find ir with a 2in lift.
Thanks
Old 04-09-2007, 07:22 PM
traben27's Avatar
with my 33x10.50's, i'm about 3 mph off on the speedometer.
and i've definitely felt a loss in power, its bearable and all, but you can feel a difference.
Old 04-09-2007, 07:26 PM
1989toy4wd's Avatar
Thanks, do you have a lift on your truck??
edit: oh, yeah, didnt read your sig!!
Old 04-09-2007, 07:41 PM
1989toy4wd's Avatar
bump??? anyone
Old 04-09-2007, 07:57 PM
Sonofmayhem's Avatar
with the 12.50s you may rub, with your rims... I've heard that a 2in body lift fixes this. you will notice a power loss but should be able to clear overpasses just fine, with 35x12.50 and 4.10s with a very slightly modded 22re i can pretty much climb passes and hills at 45, mine is dead on till 30 then it goes up to about 5mph off.
Old 04-09-2007, 08:20 PM
MMA_Alex's Avatar
you'll rub on the pinch weld. if you're going from stock 28's to 33's the spedo will be way further off than 3mph. The sr5 probably came with 31's to start.
Old 04-10-2007, 12:35 AM
ovrrdrive's Avatar
My truck came with 28" tires stock and with 32x11.50's the speedometer was exactly 10% off verified by gps over the entire range. IE, at 30 I was really going 33, at 70 I was really going 77.
When you change the gear ratio by putting on larger tires the change in the speedometer will be by a percentage, not by a single number...
Old 04-10-2007, 01:25 AM
Ganoid's Avatar
I was wondering when some one was going to mention the percentage issue.
Old 04-10-2007, 03:21 AM
Yotaboy's Avatar
I have 33 12.50s on my Runner with a 2 inch body and t bars cranked and i still rub the pinch welds on hard turns. Now I have custom cut tires I think they will rub on yours but a body lift should limit it.
Old 04-10-2007, 05:25 AM
first4runner's Avatar
I ran 33x12.50's with no lift at all for a while with very little rub. But I have a 3 in BL now and I dont rub at all.
Old 04-10-2007, 07:04 AM
MMA_Alex's Avatar
from what ive read the 4 runners seem to be able to handle larger tires without rubbing. the difference between my 28's, and the 32's i have ends up being just above the 10% stated above
Old 04-10-2007, 09:32 AM
JamesMk4's Avatar
Definitely. I have 33 12.50's on my 94' 22RE pickup and my speedo is over 10% off. With a 2" body lift and 8" wheels with 3.75" offset I slightly rub the pinch weld when fully turned and driving over bumps off road. I also had to mod the front bumper valance because the tires would rub while cornering at low speeds. After switching from after market 31 10.50's to the 33's I felt a significant difference in power.
Old 04-16-2007, 06:47 AM
Ksane's Avatar
Works on my mine
I put 33-12.50's on my 87' 4Runner DLX before I found this forum. The only "lift" is a 3" block in the leaf springs because the back end was sagging. All the leaf spring lift did was make it perfectly level, so I don't consider it a lift in any way. The 33-12.50's fit just fine (I measured all around in front before getting them). They rub just barely when I crank the wheel hard all the way to the left. I'm so used to not cranking the wheel hard to the left that I don't even think about it now, so it never rubs :-)
I didn't do anything to the torsion bar. If it make a difference-the wheels are backspaced 4". Not sure what people here think about lowing air in the tires but I run mine at 25 psi (cold), the psi on the tire says 35. Otherwise it's pretty rough riding on the country roads I live on. The tires don't squat at all because the truck doesn't weigh a lot.
Any ideas on tire pressure?
Old 04-16-2007, 06:52 AM
4banginRunner's Avatar
i ran 33x12.50s on both my 90 4Runner (3" body lift) and my stock height 79 Pickup with absolutly no rubbing issues, now i am currently running 35x12.50s on my 4runner and only minor rubbing on the back of the front fender at full lock
Old 04-16-2007, 06:55 AM
Buck01's Avatar
I run 33x12.50's with 3 inches of body lift.
Old 04-16-2007, 07:47 AM
AH64ID's Avatar
slosurfer runs 33x12.50's with no lift.. I dont count BJ spacers or tbar crank as lift, as they do not increase the room for tires.... All he rubbed on was the pinchweld, which can be beaten out of the way...
You will need to run 15x8 with 3.75" BS to make it work.. then just hope as each rig is a little different.
stormin94
02-13-2012 07:27 PM
9422re
08-12-2011 09:30 AM
CrazyEye
01-21-2010 01:50 PM
wunbigtacoma
21
10-27-2009 08:22 AM
81-yota
12-15-2008 11:11 AM
Quick Reply: 33-12.50's????
