22rte wont start - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-12-2008, 11:32 AM   #1 (permalink)
22rte wont start
any help im geting fuel to the cold start injecter and i have spark cant figure out what it can be timing has been checked. The engine was just rebuilt anyone know what it can be. there is a white double plug under the intake by the fire wall one plug goes to the transmission where does the other one go.
86turbotoy is offline
Old 12-12-2008, 12:07 PM   #2 (permalink)
annoyingrob's Avatar
Is the distributor 180* out?
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders.
91 1.5JZ GT40 Supra.
77 Celica Liftback. (WTB: 20R Carb!)
annoyingrob is offline
Old 12-12-2008, 12:13 PM   #3 (permalink)
TOYOTA 1's Avatar
^x2.. does it even try to run?
there should be 3 plugs..
1 goes to the tranny for reverse lights. one goes to the o2 sensor, and one goes to you transfer case for the 4x4 light.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 12-12-2008, 12:16 PM   #4 (permalink)
tc
tc's Avatar
Only 3 things to check - fuel, spark, air(compression) and you've checked 1.5 of them.
x3 for distributor 180* out.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-12-2008, 12:40 PM   #5 (permalink)
it wont even attept to fire i have checked the timming a couple times. I cant put my finger on what is wrong its driving me crazy.
Old 12-12-2008, 01:16 PM   #6 (permalink)
anyone got any other ideas
Old 12-12-2008, 04:33 PM   #7 (permalink)
regularjoe's Avatar
would you have spark even if it was 180 out? I dont know alot about the subject.
regularjoe is offline
Old 12-13-2008, 10:32 AM   #8 (permalink)
I belive it would have spark if it was 180 out. i have spark but it is very faint i think it might be the ignighter anyone know how to check if its good.
Old 12-13-2008, 10:45 AM   #9 (permalink)
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
If its isnt even turning over check
1. starter is actually in the hole, i had mine fall out on the way home from work last week, and wire brush the contacts and terminal
2. check fuses takes about 4 minutes to check all of them
3. make sure all of your grounds are hooked up (valve cover, chasis to engine coming of starter wire)
If it is rotating but not catching check
1. if it cranks all slow or backfires out of the air box, turn your dist around
2. pull the 19mm bolt going to the fuel rail, you will need a new crush washer, and see if you have a steady stream of fuel with the key turned to acc. dont try to start but see if you have constant flow (fill a beer can in a minute or so), if this is weak it could be sending unit, pump or pressure reg.
3. make sure all of your plug wires are on the correct spot, plug wire 1 on the number 1 location on the cap.
4. Spray some brake cleaner in the throttle body while attempting to start, and see what that does.
__________________
John Stranko
89 Toyota Pickup - 22R-E
AutoZone Fog Lights
Blue Interior w/ brown dash
American Racing 767's - 31x10.5 YOKO's
Thats all the mods I got
I think St. Patties Day is unAmerican. I technically celebrate St. Patties every night of the year, I dont need a holiday to justify it.
89whitetoyota is offline
Old 12-13-2008, 11:18 AM   #10 (permalink)
the moter turns over fine all my grounds are hooked up im getting fuel to my cold start injecter. its just like theres not alot of spark
Old 12-13-2008, 12:13 PM   #11 (permalink)
TOYOTA 1's Avatar
weird.. is there somebody you could swap out igniter/coils with?
__________________
TOYOTA 1 is offline
Old 12-13-2008, 12:35 PM   #12 (permalink)
ya i have wait till monday my friend has more toyota parts than he know what to do with 7 bays full.
Old 12-13-2008, 05:46 PM   #13 (permalink)
Have you pulled the plugs to veriify fuel is being injected? You will have pressure but if the injectors are not firing all is for nothing. This happened to me after a head gasket change. The wires got pulled loose from the plug. The connector was tight but no contact was being made. Check the wires and connector coming of the silver finned box on the passenger side firewall. It will be an insulated 2 wire white with yellow connectors.
mistreatedtoys is offline
Old 12-13-2008, 10:08 PM   #14 (permalink)
New cap, rotor, plugs, and wires?
__________________
Old 12-13-2008, 10:30 PM   #15 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
I'm wondering... how do you check the timing if the engine won't start?
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 12-13-2008, 10:32 PM   #16 (permalink)
20r/22r/22re/22rte
crank at 0
cam at 0: intake and exhaust valves loose on #1 cylinder
distributor removed, rotor at 12 oclock, insert, should rotate CCW to about 10 oclock.
__________________
Old 12-13-2008, 10:33 PM   #17 (permalink)
874runnersr5's Avatar
Quote:
x2.....
__________________
87' 4runner Sr5 : 22re : 5spd : 32x11.5 BGF Km2 : Cragar 15x8 soft 8s : TG Rock Defense Front Bumper : Sirius radio : Optima Red Top : Pioneer system : Engnbldr tchain kit : Downey 3" leafs : Diff breather : Tube doors : Bikini Top
Calgary Toyota Association
I <3 my Toyota
874runnersr5 is offline
Tags
22rte, fuel, pictures, rail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
accidentally hit the clutch start cancel button now wont start up after off 89whitetoyota 86-95 Trucks & 4Runners 55 12-04-2008 04:31 PM
wont start 89yota_mudrunner 86-95 Trucks & 4Runners 4 04-08-2008 08:10 PM
88 That wont start 4Runner_Rebuild 86-95 Trucks & 4Runners 2 03-09-2008 10:48 PM
22RTE: Finally wants to start...but won't Bill 86-95 Trucks & 4Runners 5 03-15-2007 06:52 PM
Recently rolled 4-runner now it wont start, why wont it ?? gtpunk18 86-95 Trucks & 4Runners 22 01-24-2007 10:25 PM
2009 InternetBrands, Inc.
