| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
-Andrew 94 4Runner 3.0 Auto. I got mods Now Back in Action! |
#27 (permalink) | ||
I'm getting some loud vibrations at about 3000rpm, I'm almost certain it is from the compressor. I'm going to check it out tomorrow.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#28 (permalink) | ||
more info on the bracket can be found here: http://yotatech.com/f116/york-air-co...r-22re-152143/. I must warn you though, that I build a bracket as per instruction off PirateBB, and it didn't fit, the one below I designed and it actually works on a stock 22RE with OEM-height engine mounts.
http://www.yotatech.com/f116/22re-yo...mplete-155162/ Used these sites when figuring out my OBA: http://www.jedi.com/obiwan/jeep/yorkair.html http://www.mudinyerioffroad.com/yorkOBA.htm I recommend doing this mod to your compressor as well so your compressor oil doesn't spill out down the air line. http://www.jedi.com/obiwan/jeep/york_oilmod.html On finding the compressor: http://www.links4jeeps.com/writeups/...ork_Donors.php
__________________
#29 (permalink) | ||
I bought an butterfly impact wrench for my truck... so now I can pop the hood, and hook up the air line undo bolts... its wicked! There's an Mastercraft air tool set for $120 at a local store- includes a 1/2" impact (250ft-lbs), air ratchet, air chisel and a bunch of regular and deep well impact sockets.
Anyone want to suggest the next air powered item i buy? I like the idea of an air powered blender. Real and frivolous suggestions welcome!
__________________
#30 (permalink) |
Hey a angle die grinder would be nice.
__________________
86 Toyota 4 runner Soild front axle, 35x12.5 BFG KM2's, winch, blah blah blah.... http://www.yotatech.com/f116/my-new-red-snappah-152938/ My cardomain page |
#31 (permalink) | |
Quote:
Crappy tire eh? I was gonna buy the exact same set, too bad Im broke
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#32 (permalink) | ||
Me too, that's the problem...but we can dream.
__________________
#33 (permalink) | ||
More pics:
![]() ![]() Bracket with pump removed for servicing: ![]() See how the bracket is bolted to the OEM 22RE A/C bracket: ![]() 4 bolts connect the bracket to the York. ![]() Sweet, twice as many pistons as I thought. Should have checked the oil before installed it. This was all that remained when I opened it up. Stupid on my part. It still works just fine though. ![]() ![]()
__________________
#34 (permalink) | ||||||||
MattTse5 and I have been cooresponding, and he's asked some decent questions:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
__________________
Quote:
More info on 4Runners Last edited by Matt16; 03-10-2009 at 08:33 PM. |
#35 (permalink) | ||
My bracket broke a while back- the welds cracked. I've since had a friend weld it back together with proper penetration. and I gussetted the living ...err.. daylights out of it. I also found out the front seal (called a "shaft seal") was toast. I replaced the seal, refilled the compressor with oil, painted it black, re-bolted everything back together and now once again have the working OBA system, but its better now because it isn't flimsy.
The shaft seal came from 4 Seasons air conditioning- a OEM replacement parts brand. My local autoparts store carries them and was able to find the correct part by searching for a AC front seal for a 1982 Ford F250 with a 6.6L engine. http://www.4s.com/ROOT-Home1/Content.aspx
__________________
#36 (permalink) |
Im still jelous
I better not let my g/f see this, or else i'l have a new project!!
__________________
#37 (permalink) | ||
I'm convinced a York can be mounted to a 3vze. It would have to sit way down low, but I think its doable. You would want to protect it with a beefy front skid though- the stock skid would be too risky.
__________________
#38 (permalink) | ||
Pleased to report that the stiffening of the bracket has totally eliminated the vibrations... but now its easier to hear the shot bearing on the compressor pulley. Not dealing with that until it welds itself solid. My exhaust rattles loud enough so that the pulley bearing isn't too irritating.
__________________
#39 (permalink) |
Haha, must be a 22re thing. Is it loose at the ypipe mount??
__________________
#40 (permalink) | ||
No, the back of the muffler is rusty and is no longer mechanically connected to the tailpipe- it just kind of sits there.
__________________
#41 (permalink) |
I just read over on H8 about the air heating up. I have a 22re AC compressor from a donor engine, that I have got mounted up on my engine and am going to start getting the parts together tomorrow for a build.
The post said the air out of the compressor can reach 300-400 degrees. Do you see those temperatures with the York? |
#42 (permalink) | ||
Don't think its that high, but it definitely heats up good.
__________________
| Tags |
| 1985, 22re, air, compressor, driven, engine, installed, oba, onboard, toyota, york |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| York air compressor, 22RE | Matt16 | 86-95 Trucks & 4Runners | 62 | 09-30-2008 08:29 PM |
| on board air | toyotaordie | General Vehicle Related Topics (Non Year Related) | 10 | 07-17-2007 12:48 PM |
| York air compressor | Ric | General Vehicle Related Topics (Non Year Related) | 3 | 01-25-2006 12:32 PM |
| Air tank for on board air | mtnbkr | Offroad Tech | 2 | 05-05-2004 06:42 PM |
