22re Running Rough When Cold and at High RPM's
Old 01-02-2014, 04:13 PM
The Tick's Avatar
Ok, so my 4runner won't idle when cold, but as soon as I give it throttle, it runs just fine. Even if I hold it at only 1,000 RPM it works ok, but as soon as it goes to idle, it dies. But if I wait till the temp gauge moves up at all, then let it idle, it's fine.
Also, when I rev it (at any temperature) I.E. When speeding up in 1st as fast as I can, it starts misfiring at ~3,500 RPM, but it still speeds up, but if I shift into 2nd and speed up quickly, it misfires horribly at ~3,000 RPM so bad that I don't speed up any more.
BUT, the fuel filter was replaced only 2,000 miles ago, so that isn't the problem, and I have done plugs and wires recently. However, my fuel sender is bad, so the gas gauge and low fuel light both don't work, which may or may not have anything to do with my problem. Thanks in advance!
-Nathan
Old 01-03-2014, 08:33 AM
The Tick's Avatar
Bump.
Old 01-03-2014, 11:30 AM
The Tick's Avatar
Anyone?
Old 01-03-2014, 11:37 AM
combatcarl's Avatar
https://www.yotatech.com/forums/show...916&styleid=51
I would also hazard a guess that your temp sensor and/or cold start injector/time switch have issues.
Old 01-03-2014, 12:06 PM
The Tick's Avatar
Thanks, I'll clean out the Throttle body. So will this have the injector and switch combined, or are they separate? http://www.ebay.com/itm/Toyota-22RE-Cold-Start-Fuel-Injector-/221346733586?pt=Motors_Car_Truck_Parts_Accessories&hash=item33894b1e12&vxp=mtr
Old 01-03-2014, 12:22 PM
combatcarl's Avatar
No, that's just the injector. And usually the injector is fine, just related electronics are the issue. Look in here for some info. These two plugs is where I'd start troubleshooting.
https://www.yotatech.com/forums/f116/86-4runner-22re-cold-start-injector-time-switch-test-out-fine-244180/
Old 01-03-2014, 12:24 PM
The Tick's Avatar
Ok, thanks. I'll take a look.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22re Running Rough When Cold and at High RPM's
