22re rebuild - what gasket do I use...copper ring?
I'm trying to figure out how this pipe is attaches to the bottom of the intake manifold. It looks like I had a small rubber o-ring. But in engnbldr's kit all I can find is a copper ring...will this work...is it enough by itself? Or is there a full gasket?
It needs a rubber o-ring, and the pipe attaches to the manifold by two small bolts. When I replaced mine I used one from a harbor freight metric o-ring kit, I even put some grey permatex on this connection for added protection ,no leaks. Also copper washers should be for fuel connections.
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
