22RE rebuild help
Old 12-28-2009, 07:34 PM
87x4runner's Avatar
Exclamation 22RE rebuild help
I'm currently in the process of swapping out my 22RE that i blew up, and noticed that there was a lot of black gunk (carbon deposits? ) on the inside of the EFI all the way to the valves. My question is how do i clean this without having to completely disassemble the the EFI? Do i need to clean this, or is this build up normal? I should be starting to reassemble the engine in the next couple of days. I'll post some pics in a bit.
Old 12-28-2009, 07:50 PM
874runnersr5's Avatar
TB or carb cleaner..
Old 12-28-2009, 09:49 PM
abecedarian's Avatar
the build up is normal for a 22re but you should clean it if you're changing the engine.
if the engine's apart, dremel, carb cleaner, brake cleaner, etc... get rid of the gunk.
the gunk is a combination of 'stuff' from the PCV and EGR.
Old 12-28-2009, 11:17 PM
87x4runner's Avatar
Photos
Here is a couple of photos. The last one is where my connecting rod pushed through the engine block...
Attached Thumbnails 22RE rebuild help-efi.jpg   22RE rebuild help-efi2.jpg   22RE rebuild help-engine.jpg
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
coleypull15
11-03-2015 07:41 AM
shisha1999
09-21-2015 08:22 PM
shadowbirdie
07-21-2015 10:38 PM
Quick Reply: 22RE rebuild help
