22RE cylinder compression/ engine removal and swap questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-23-2006, 05:19 PM   #1 (permalink)
the4x4runner's Avatar
Send a message via AIM to the4x4runner
I have a 86 4runner 22RE 5speed 4X4 IFS that has poor compression in #1 cylinder.
The compression is only bad in the cyclinder and improves when oil is added meaning its the rings or the cylinder. The engine leaks oil from the pan and the dipstick, maybe other places. The dealership wants an outragous amount just to open it up and look to see whats wrong. I think its bad when he starts quoting me prices to just replace the block. ($3500-$5400).
I only paid 1k for it and dont want to , nor can pour alot of money into it right now. It may be as simple as changing the rings, but i dont have the money to have the rings replaced or cylinders machined and dont want to get into opening up the engine. I have found a complete engine w/ 100K that runs well and was thinking of just swaping engines. i think i can handle that (I have some friends and can rent a hoist).
I've done some searching to find if i need to remove the tranny to take the engine out with no luck.
Can i unbolt the tranny and remove the engine ( after everthing else is unplugged/unbolted), or do they have to come out together.
This is unless there is some miracle stuff you can add to improve the seal of the piston rings. i think that is why my oil leaks, because the combustion of the engine is leaking into the oil pan and causeing excessive pressures.
Thanks for any input
the4x4runner is offline
Old 07-23-2006, 06:07 PM   #2 (permalink)
ovrrdrive's Avatar
Well, how much are you paying for the engine with 100k on it?
If its under $400 I would be tempted to do it but anymore than that and you are asking for trouble.
And keep in mind that this engine is only a band-aid. It's highly possible that you'll need to replace it again in a few years...
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 07-23-2006, 07:28 PM   #3 (permalink)
the engine selling for 400 or 450. ive only put 60K on my other truck in the last 5 years, so i think itll last me.
Old 07-24-2006, 08:28 AM   #4 (permalink)
Send a message via AIM to Adams90Toyota
I have a 90 pickup with a 22re and i had to replace about the whole motor, but i took the tranny off and didnt pull it with the motor.
Adams90Toyota is offline
Old 07-24-2006, 08:39 AM   #5 (permalink)
4Hummer's Avatar
I left the tranny in, Unbolt from the flywheel. 4 hours and I got this
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 07-24-2006, 09:00 AM   #6 (permalink)
ironroad9c1's Avatar
Send a message via Yahoo to ironroad9c1
i've done it both ways ,and to tell the truth i'd rather unbolt the tranny that pull the whole thing ,gets kinda tight around the front axle and sway bar area and t case .
__________________
2004 crown vic lx sport
1989 caprice 9C1 lt1/4l60E swap.
ironroad9c1 is offline
Old 07-25-2006, 03:48 PM   #7 (permalink)
It is kind of hard to get to a few of the bolts tho.
Tags
22re, 4runner, 87, compression, crown, cyl, cylinder, engine, head, ifs, motor, number, removal, swap, vic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What should cylinder compression be? baileymoto 95.5-2004 Tacomas & 96-2002 4Runners 2 08-21-2006 11:49 AM
Cylinder head removal questions. Fastest way to do it? vmax84 86-95 Trucks & 4Runners 3 06-08-2006 04:25 PM
22re low compression #1 cylinder bigbear4 95.5-2004 Tacomas & 96-2002 4Runners 11 09-16-2004 07:19 PM
Proper Engine Compression on 87 22re? beelzabubba 95.5-2004 Tacomas & 96-2002 4Runners 1 08-25-2004 05:48 PM
Engine removal questions patterson 95.5-2004 Tacomas & 96-2002 4Runners 6 05-10-2004 04:59 AM
2009 InternetBrands, Inc.
